FS: 30" TMX Blackhawk LED Bar
  • Start date
Status
Not open for further replies.
This bar will fit behind the grill above the Ford without any brackets. You just have to drill two holes. This is where I have had it since I purchased it.
This is the write-up that I followed and fit perfectly.
http://www.fordraptorforum.com/f81/30-kc-hilites-led-upper-grille-install-no-brackets-25682/
Here is a link of the actual bar from TMX's website:
https://www.txmotorworx.com/blackhawk-led-30-light-bar.html
$200 shipped in the lower 48, FIRM. Any PayPal fees paid by buyer.
Want to get this sold, $225 SHIPPED. I am giving it away at that price.
Wfo
Syracuse
I may be interested. Does it have a deutsch connector? Will it fit the SCV Baja bumper?
Yes on the connector, pic included. I do not know about the SVC bumper, when I ran that bumper, I had a Rigid. I sold the Rigid and the buyer did put it in the same location where I had this Blackhawk, behind the grill above the Ford. I can tell you that it is 32 1/4" long from mount to mount, if that helps.
Do you have the wiring harness and switch also?
Or just the light bar
Just what you see but I have some extra stuff in the garage that I can see if I have anything that might work. But wouldn't you just use one of your AUX switches with this?
Colleyville Tx
I shouldn't be buying this right now but I'll give you $200 for it if you'd part with it for that much. I'll send the cash right now. Through PayPal?
Status
