vince7870
Ok guys I posted some pics of some custom center caps I had machined for my method nv wheels. A lot of guys responded with interest in having me get them a set. They are machined out of 6061 aluminum and machined to fit the method wheels with no movement whatsoever. The taper duplicates the taper of wheel and uses a high temp high pressure oring which causes enough pressure to take up any slack and create a tight fit.
Sorry it took so long but I wanted the fit and finish to be perfect.
These caps will fit any method wheels with a bore of 94 mm and rim thickness of 30.5 mm. They will fit snug and be as flush as possible.
The caps could be anno'd black red blue or left raw machined to match the machined method wheels.
The engraving could be done within reason to whatever you desire.
I am currently working on having a set made up with my avatar engraved in the face.
Here are a few pics.
The cost is $200 plus $20 for a set shipped to lower 48 states. If they need to be shipped out of the country please contact me and we'll figure out what it costs.
You can always pm here on the forum or you can email me at [email protected]
If you guy are interested the first batch of 10 sets is being made.
Thanks birdman!
Thanks birdman!
