Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Classifieds Forum > Garage Sale
Garage Sale
Bed Bolt D-Ring Tie Down Points AT COST
This is a discussion on Bed Bolt D-Ring Tie Down Points AT COST within the Garage Sale forums, part of the Ford Raptor Classifieds Forum category!
Like Tree11Likes
Old 05-28-2018, 01:52 PM   #1 (permalink)
Talbor's Avatar
Default Bed Bolt D-Ring Tie Down Points AT COST
Iím taking orders for ready-to-install bed bolt mounted D-ring tie downs AT COST.
After doing some research, I found this solution for mounting my 2nd spare: Bed bolt tie down install
I installed 6 of these for TRR to secure my recovery kit and 2nd spare and they were AWESOME. They held up great, were beefy, and very functional as a tie-down point for multiple ratchets. The straps I used were 2Ē locking ratchets with hooks from Amazon for $30 (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ). You could use something less beefy, like some 1Ē or 1-1/2Ē straps, but I like the look of the bigger ones. Weíre only talking about a 100lb tire/wheel Ė I think two 2,500lbs WLL straps might be a bit overkill.
Process to make these:
ēOrder rings from a MOPAR parts supplier (I know, I know Ė sacrilege)
ēGrind to fit bed bolts
ēTouch-up paint with black gloss high-temp enamel engine paint (hardest stuff I know of to prevent chipping)
How to install:
ēRemove bed bolts with T-50 Torx PLUS bit - https://www.amazon.com/dp/B000O846UI?ref=yo_pop_ma_swf
ēPush bed bolt through d-ring and ďhand tightenĒ bed bolts
ēUse a ratchet strap to keep d-rings from rotating while applying final torque
ēTorque bed bolt to 56-ft-lbs
Supplier: https://www.tascaparts.com/oem-parts...iner-5170492aa
Pricing:
If I order 12 at a time to save on shipping, the best price I can find for these online from a reliable source is $91.56 (including shipping). That comes out to $7.63 per ring. Iím rounding up to $9 to cover consumables (black high temp engine enamel paint, eventual replacement of my angle grinder wheel, 1 beer).
Cost:
ēShipped: $9 each d-ring + $8 shipping (USPS flat rate box)
ēLocal pick-up (Houston): $9 each D-ring (Iíll help with the install)
How to Order:
PM me with what you want, whether you want to pay through Venmo or PayPal, and Iíll send you the total. Iíll order your stock once I receive payment. Delivery time will vary since I only bought a few to start and might have to order more, but from payment to your doorstep should be within 2 weeks or less.
FAQs:
Q: Why are you selling these at cost?
A: Well, Iíve seen plenty of posts where fellow owners are looking for a bolt-on solution and don't want to hassle with the modification to the d-rings. With the cost of tools and setup, having 2 young kids, I understand that can be cost prohibitive for some and the time to modify the rings can be a factor. One of my favorite tools to use is an angle grinder (sparks flying!) and since Iím all setup, it only takes me 10-15 mins total time to make a set of 6, unless Iím changing color. So, Iím glad to have a little fun DIY action and help out fellow Raptor owners out at the same time who also contribute to this forum and community.
Q: Why donít I just order one of the 3-point ratcheting strap kits available from one of the vendors?
A: If you like your tire mounting solution, you can keep your tire mounting solution! I like the looks of those kits too, and only having one ratchet is nice. Plus, if youíre looking at just mounting a second spare, the cost for 4 rings plus the straps I used ($40 + $30 = $70) is getting pretty close to the cost of the 3-point ratchet kits ($100ish). I didnít go that route for a couple reasons: 1) I didnít want to drill new holes into my bed and worry about loads on the aluminum, even with some reinforcement, 2) I use my truck a lot for its utility and wanted the extra 6 tie-down points, and 3) the solution I used still looks really clean and fit for purpose.
Q: Can I get a discount?
A: Iím selling these at cost. Not looking to make any money, just offer up an easy and clean solution for other owners. If you pick them up, Iíll throw in a firm handshake.
Let me know if you want a set. I only have 1 set (6) on hand right now, so Iíll wait a few days to see if thereís some interest and Iíll make a large order from the Mopar dealer.
Cheers!
Talbor is offline   Reply With Quote
Old 05-28-2018, 02:03 PM   #2 (permalink)
whoisbigman's Avatar
I have a Gen 1... are these the same size? will they work for me?
2012 Tux Black, Loaded. Previous owner added Spray-in liner, bed cover, LED everything, AFE intake, Magnaflow Exhaust, mid-perch... other stuff I haven't found yet. Thank You whoever you are... I have added 37" Nitto tires, painted speaker grilles, Roush vacuum gauge for hubs.
whoisbigman is offline   Reply With Quote
Old 05-28-2018, 02:11 PM   #3 (permalink)
Talbor's Avatar
According to this post - Cheap Bed Ring MOD - they work on the Gen 1 Raptors.
I have a buddy coming over tonight with a previous gen F-150 that I can test fit them on to verify. I'll check and report back.
Old 05-28-2018, 05:45 PM   #4 (permalink)
Great karma..... good stuff.
These do indeed fit Gen 1.
Talbor likes this.
2012 Race Red SCREW
Build thread: http://www.fordraptorforum.com/f65/t...7/#post1203840
tcm glx is offline   Reply With Quote
Old 05-28-2018, 06:21 PM   #5 (permalink)
Clockton's Avatar
ē Order rings from a MOPAR parts supplier (I know, I know Ė sacrilege)
ē Grind to fit bed bolts
ē Touch-up paint with black gloss high-temp enamel engine paint (hardest stuff I know of to prevent chipping)
How to install:
ē Remove bed bolts with T-50 torx bit
ē Push bed bolt through d-ring and ďhand tightenĒ bed bolts
ē Use a ratchet strap to keep d-rings from rotating while applying final torque
ē Torque bed bolt to 56-ft-lbs
Pricing:
Cost:
ē Shipped: $9 each d-ring + $8 shipping (USPS flat rate box)
ē Local pick-up (Houston): $9 each D-ring (Iíll help with the install)
ē Extras:
o Custom color: $10 per order Ė can of paint and multiple coats (time)
o T-50 Torx bit for 1/2" drive: $7 or you can just get one from Amazon: https://www.amazon.com/Lisle-26640-T...ords=t-50+torx
How to Order:
PM me with what you want, whether you want to pay through Venmo, PayPal, or cash (local pickup), and Iíll send you the total. Delivery time will vary since I only bought a few to start and might have to order more, but from payment to your doorstep should be within 2 weeks or less.
FAQs:
Cheers!
I used 4 of these in the back seat area bolted through the body. 2 Behind the driver side and passenger side seat each. There are great for tieing down the miscellaneous crap in the cab so it doesn't fly around.
Talbor likes this.
Clockton is offline   Reply With Quote
Old 05-28-2018, 08:26 PM   #6 (permalink)
Otis857's Avatar
Thanks Talbor. PM sent
Talbor likes this.
Mike
2011 Scab
"Of all the things I've ever lost, I miss my mind the most"
Otis857 is offline   Reply With Quote
Old 05-29-2018, 10:04 AM   #7 (permalink)
Talbor's Avatar
Yup - can confirm. They will work on a Gen 1.
Iíve got a couple order requests and will wait until the end of the day (and until I receive payment) to order the stock to modify and send out. Any ordered today should arrive by the end of next week.
Old 05-29-2018, 11:35 AM   #8 (permalink)
If you grind away the bolt side of the bit that secured the ring how much weaker will it be? Doesn’t appear to be much material there to start with....
---------- Post added at 03:35 PM ---------- Previous post was at 03:32 PM ----------
I’d also consider the liability if you provide these. Hate to be that way but someone loses a load if it breaks and you might get sued. Hard to just be a nice guy :(
Carnut is offline   Reply With Quote
Old 05-29-2018, 11:49 AM   #9 (permalink)
HAP's Avatar
HAP
Don't grind the bit, just torque them down without the OEM washer and it will be fine.
R,
HAP
Who Do I Think You Are?
HAP is offline   Reply With Quote
Old 05-29-2018, 11:56 AM   #10 (permalink)
Talbor's Avatar
Originally Posted by Carnut View Post
If you grind away the bolt side of the bit that secured the ring how much weaker will it be? Doesnít appear to be much material there to start with....
Iíd also consider the liability if you provide these. Hate to be that way but someone loses a load if it breaks and you might get sued. Hard to just be a nice guy :(
Thereís still plenty of metal holding in the d-ring, but I canít accurately say what the de-rating is. In fact, I donít know what the rating of the d-ring is unmodified - itís not stated on any documentation or website that I can find. However, for comparison, these d-rings are rated for a 1,000lbs WLL with a break strength of 3,000lbs, and theyíre considerably smaller.
Not a bad idea on the liability side. Iíll print out a general release of liability letter and include it with the D-rings. I personally have no concern about these breaking before any straps that I use.
---------- Post added at 10:56 AM ---------- Previous post was at 10:55 AM ----------
R,
HAP
It doesnít interfere with the OEM washer, but with the bed bolt itself - see the picture in the original post.
Powdercoating Bead Lock Ring - COST? 7raptor Ford Raptor Wheels & Tires Forum [GEN 1] 14 11-05-2014 06:41 PM
Take beauty ring off and install REAL beadlock ring WITHOUT changing the bead??? srt10viper Ford Raptor Wheels & Tires Forum [GEN 1] 7 08-22-2014 02:51 PM
Beadlock beauty ring bolt - help! RDFTS Ford Raptor Problems and Questions Forum 14 08-21-2014 12:57 PM
Jacking points Hoverp Ford Raptor Maintenance Forum 1 05-16-2014 05:53 AM
tie-down points offroadshadow Ford SVT Raptor General Discussions [GEN 1] 8 01-27-2011 07:49 PM
