Front 1-1/2" Lift Leveling Kit for all 2017 F-150 Raptors
CJ Pony Parts
Harrisburg, PA
Front 1-1/2" Lift Leveling Kit for all 2017 F-150 Raptors.
In this video, Freddy & the crew at CJ's will show you how to install this Front 1-1/2" Lift Leveling Kit on your 2017 F-150 Raptor from the comfort of your own shop or garage!
If you are looking to level out the front and rear ends of your 2017 F-150 Raptor this Front 1-1/2" Lift Leveling Kit is the perfect solution. Constructed from 6061T6 aluminum with 316 stainless steel hardware included, these Coil Spring Collars are specifically designed to work with the Fox 3.0 shocks that are the factory shocks on your 2017 F-150 Raptor.
Features and Benefits:
- Constructed from 6061T6 aluminum
- Front end raises by 1-1/2" to level with rear
- Moves lower spring perch up on the front strut body
- Made to work with Fox 3.0 shocks (factory shocks on 2017 F-150 Raptors)
- Does not affect bump travel or droop
- Includes 316 stainless steel hardware
- Includes enough parts and hardware to level one F-150 Raptor
- Made in the USA
Easily installed, this Front 1-1/2" Lift Leveling Kit will leave both bump travel and droop completely unaffected. Including the stainless steel hardware, this pair has everything you will need to level one F-150 Raptor. You will not be required to disassemble or remove your Fox 3.0 shocks during the installation of your new Coil Spring Collars. Installation will move the lower spring perch up on the front strut body. All the components and hardware included is made in the USA.
Please Note: Installation will require partial disassembly and removal of the factory shocks. A heavy-duty spring compressor will be needed to complete the installation.
Order this Front 1-1/2" Lift Leveling Kit for your 2017 F-150 Raptor today from CJ Pony Parts.
