Fog Light Bezel and Mounting Kits for the 2017 Raptor
We have several variations of this kit now available! The Fog Light Bezel and Mounting Kit with a Pair of KC HiLiTES Flex LED Lights is basically the base kit. This kit will allow you to equip the remaining open slots in the bezels with whatever 3" cube lights you see fit.
Fog Light Bezel and Mounting Kit with a Pair of KC HiLiTES Flex LED Lights for 2017 Raptor F-150s.
Fog Light Bezel and Mounting Kit Includes:
- Pair of two (2) stainless steel black powder coated bezels and mounting brackets
- Paintable molded ABS bezel kit
- Stainless steel bracket and light mounting hardware
- Pair of two (2) silicone gaskets
- Pair of two (2) KC HiLiTES Flex LED Lights with black bezel rings
- Able to mount additional two pairs of 3" LED cube lights (sold separately)
If you're looking for a way to increase your off-road or nighttime visibility, than this fog light bezel and mounting kit is exactly what you need! You can add up to two pairs of 3" LED cube lights to the front of your new Raptor, allowing you to have a better field of vision with stronger, clearer lights. CJ's has included almost everything you need to get started with these lighting upgrades--just be sure to grab two additional pairs (4 total) of cube lights from KC HiLiTES, Rigid Industries, Baja Designs or Vision-X and you'll be good to go! This kit is made entirely in the U.S.A. and includes the bezels and mounting brackets as well as all hardware and gaskets you'll need to install the six cube lights. Your new Raptor F-150 is begging for some upgrades, so starting with the lighting and electrical is a definite no-brainer! Order this Fog Light Bezel and Mounting Kit with a KC HiLiTES Flex LED Lights from CJ Pony Parts today!
Please Note: This bezel can accommodate up to two pairs of 3" cube LED lights, and includes one pair of KC HiLiTES Flex LED lights. The two additional pairs of 3" cube lights must be purchased separately.
Serious off-road enthusiasts know that the F-150 SVT Raptor has specialized all-terrain and powertrain components, which make it the pickup to own when you want to traverse sand, mud and countless forms of other intense terrain, at very high velocities. Get the most out of your new Raptor F-150 with high-quality performance and off-road upgrades today!
Here are some of the great kits that we have put together that will take out the guess work when equiping your new bezels with the correct 3" cube lights.
Fog Light Bezel and Mounting Kit with Rigid Industries LED Dually Spot Lights and Flood Lights
Kit Includes:
- Pair of two (2) Rigid Industries LED Dually Spot Lights (20221)
- Pair of two (2) Rigid Industries LED Dually Fog Lights (20211)
Fog Light Bezel and Mounting Kit with Rigid Industries D2 LED Spot Lights and Flood Lights
Kit Includes:
- Black Powder Coated Fog Light Mounts
- Molded ABS Bezels
- Stainless Steel Mounting Hardware
- Pair of Silicone Gaskets
- Pair of Rigid Industries D2 Driving lights
- Pair of Rigid Industries D2 Wide Flood lights
- Pair of KC HiLiTES Flex LED Lights with Black Bezel Ring
Fog Light Bezel and Mounting Kit with 3" LED Cube Spot Lights and Flood Lights
Kit Includes:
- Pair of Black Powder Coated Fog Light Mounting Brackets
- Pair of Paintable Molded ABS Bezels
- Pair of 3” LED Spot Lights (36534)
- Pair of 3” Flood Lights (36533)
- Pair of KC HiLiTES Flex LED Lights with Black Bezel Rings
Fog Light Bezel and Mounting Kit with Rigid Industries LED Radiance Pod Lights with White Backlights
Kit Includes:
- Pair (2) Stainless Steel Black Powder Coated Fog Light Mounts
- Paintable Molded ABS Bezels
- Pair (2) Silicone Gaskets
- Two Pairs (4) Rigid Industries Radiance Spot Light Pods with White Backlights (20200)
- One Pair (2) KC HiLiTES Flex LED Lights with Black Bezel Ring
Fog Light Bezel and Mounting Kit with Rigid Industries LED Radiance Pod Lights with Amber Backlights
Kit Includes:
- Two Pairs (4) Rigid Industries Radiance Spot Light Pods with Amber Backlights (20204)
Fog Light Bezel and Mounting Kit with KC HiLiTES C-Series White LED Spot and Flood Lights
Kit Includes:
- One (1) Pair of Stainless Steel Black Powder-Coated Bezel and Mounting Brackets
- Paintable, UV-Stable Molded ABS Bezel Kit
- Stainless Steel Bracket and Light Mounting Hardware
- One (1) Pair of Silicone Protective Gaskets
- Mounting Capability for 2 Pairs of 3" Cube Lights and 1 Pair of KC HiLiTES Flex LED
- One (1) Pair of KC HiLiTES C-Series White LED Spot Beam Cube Lights
- One (1) Pair of KC HiLites C-Series White LED Flood Beam Cube Lights
- One (1) Pair of KC HiLiTES Flex LED Lights with Black Bezel Ring
Fog Light Bezel and Mounting Kit with KC HiLiTES C-Series Amber LED Spotlights and White LED Flood Lights
Kit Includes:
- One (1) Pair of KC HiLiTES C-Series Amber LED Spot Beam Cube Lights
- One (1) Pair of KC HiLiTES C-Series White LED Flood Beam Cube Lights
Take a moment to check out the several variations of this kit now available!
Kit Includes:
Kit Includes:
- Molded ABS Bezels
Kit Includes:
Kit Includes:
Kit Includes:
Kit Includes:
Kit Includes:
