aFe Stage 2 Momentum GT Cold Air Intake System w/Pro Dry S Filter for 2017-18 Raptors
CJ Pony Parts
Harrisburg, PA
aFe Stage 2 Momentum GT Cold Air Intake System with a Pro Dry S Filter for 2017-2018 F-150 Raptors.
Increase the amount of cold air being pulled into your new 2017-2018 F-150 Raptor engine while maintaining an easily inspected filter with this aFe 51-73115 Stage 2 Momentum GT Cold Air Intake System. Adding aggressive style, this cold air intake system is designed to achieve maximum power gains while maintaining a perfect fit under your Raptor's hood.
The smooth one-piece sealed housing is used to eliminate the use of multiple-piece housings and ensure the coolest air intake charge available. A large, clear sight window is used for a hassle-free filter inspection and an aggressive style. This System uses a CAD designed, dyno-tuned, roto-mold intake tube to achieve maximum power gains while maintaining a perfect fit.
The Momentum GT intake is designed around an oil-free, large 9-inch tall conical inverted top 360 degree radial flow performance air filter with 3-layers of progressive finer porosity synthetic media providing maximum convenience. The unique air filter-to-housing interface allows for maximum filter size which increases the available air volume while simplifying the installation process.
Premium stainless steel T-bolt clamp and silicone couplers are used for strength and durability while also providing the most secure installation available. Momentum GT intakes are designed with fewer parts for a quick and simple installation that does not require modifications to your 2017-2018 F-150 Raptor.
Cold Air Kit Features and Benefits:
- CAD-designed roto-molded intake tube
- One-piece sealed housing
- Built-in sight window provides easy inspection of filter without disassembly
- Unique filter-to-housing interface for easy installation
- Pro Dry S oil-free 3-layer progressively finer porosity synthetic media for maximum convenience
- No cutting or drilling on factory parts for faster installation
Please Note: This intake system is not CARB exempt at this time and is not for use in California or on vehicles registered with the California Department of Motor Vehicles.
Order this aFe 51-73115 Stage 2 Momentum GT Cold Air Intake System with a Pro Dry S Filter for your 2017-2018 F-150 Raptor today from CJ Pony Parts.
Msb.19d
Broadway, NC
Why don’t you post a price with any of these things your posting for sale. They have been out on market for awhile now. A cheap price would be good to see posted under them or something
CJ Pony Parts
CJ Pony Parts
Harrisburg, PA
Click on the link and view it on our website, all of our prices are clearly stated there. Typically there will even be more information and images on our website. Along with a TON of other parts I'll never have time to post on here.
