who's using Dynamat?
EricM
OHIO
Enough for what specifically? I put something like six boxes into a Mustang, that covered the whole floor, both doors and door pillars and the trunk area. Nothing on the roof or the trunk lid. Check out Second Skin as well. I used both and there was basically no difference other than price and the Dynamat logo.
I found the wood rollers were the best way to apply it. Rubber rollers gave too much.
Toadster
Toadster
Folsom, CA
looking at doing all 4 doors, some inside the door cavity but primarily to cover the surface behind the door skins
EricM
OHIO
I think you'd be OK with that box if you don't plan to cover every square inch of the door panel, which you really don't need to do. I have a feeling you'll want more once you start though. You might as well get some extra- you can use it in the future if you don't need it. It's good for quieting down lots of stuff. I put some on the inside of the outer door skin (along with Dynaliner) and on the power window parts I could get to. The doors are so much quieter and close with a nice thud.
You won’t gain a discernible reduction in road noise.
I’ve dynamatted the 4 doors under the trim, all for naught apparently since it will get torn out for the recall.
I also did the sub enclosure after upgrading the sub and adding an amp. Very big difference there.
shelteredraptor
on a rock
If you're going to take the doors apart, do them complete.
Toadster
Toadster
Folsom, CA
what recall?
---------- Post added at 02:36 PM ---------- Previous post was at 02:30 PM ----------
this Noico stuff looks to be 1/2 price - a little thinner, but ....
Noico 80 mil 36 sqft car Sound deadening mat
what recall?
door latch recall; they have to tear apart and eval the locks. I know one of my door locks is a goner, difficult to operate and slow to return to locked. :-(
3-4 boxes to do the entire interior. 2 -2.5 boxes to completely cover the doors
Could you clarify what size boxes - that is, what size of rolls you’re using and how many sheets per box?
I used more than that in dynamat rolls, but to be clear it was my first usage of dynamat.
