- Joined
- Dec 16, 2016
- Posts
- 16,292
- Reaction score
- 24,027
Thanks for that video. It has successfully turned me off of the idea of adding a PAC for now.
what he said.
This a job I am capable of doing, but will sap a lot of my time, probably a factor of 3-4 x the time a pro would take to do it.
I imagine it works well, but something I’d consider hiring someone to do, if I go down this path.
I'm surprised Noah hasn't chimed in to explain this. It's not bad to do, and it converts the signal out of the head unit to an RCA level output to accurately bypass the factory amp so you can easily go to a processor. Mine is sitting right under the shelf in the upper dash and you simply run some long RCA's back to the 6to8. Use really good cables and be very careful about the routing so you don't pick up any low level interference(noise)
