Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 2]
Which Lowrance would you go with??
This is a discussion on Which Lowrance would you go with?? within the Ford Raptor Audio/Video/Electronics Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Like Tree2Likes
Old 07-09-2018, 03:12 PM   #11 (permalink)
jackrook's Avatar
Originally Posted by 1BAD454SS View Post
16 w is an antenna only the point 1 is antenna , and compass ,+ fast refresh rate. HDS9 carbon on my rig
Seeing as Iím going on 2-4 Raptor runs a year, Iím ok with a slower refresh rate.
jackrook is offline   Reply With Quote
Old 07-09-2018, 08:15 PM   #12 (permalink)
MatMan's Avatar
Originally Posted by jackrook View Post
Good to know. I decided to just stick with my 5 elite. Just gonna get the 16w tomorrow.
---------- Post added at 10:21 AM ---------- Previous post was at 10:20 AM ----------
Can you point me in the direction of the $65 antenna
Lowrance LGC-16W Elite GPS Antenna with 20' Cable - Lowrance 000-00146-001 - Lowrance Antennas - Lowrance/Eagle Accessories - Accessories - Boatersland Marine
Or
https://www.thegpsstore.com/Lowrance...SABEgLjlfD_BwE
MatMan is offline   Reply With Quote
Old 07-10-2018, 01:28 AM   #13 (permalink)
Darthyota's Avatar
I like my Garmin GPSMap 7410
Darthyota is offline   Reply With Quote
Old 07-10-2018, 09:29 AM   #14 (permalink)
jackrook's Avatar
Looks super sharp! How does it perform?
Old 07-10-2018, 10:38 AM   #15 (permalink)
Clockton's Avatar
I have the HDS Carbon 7 and I haven't needed an external Antenna. The internal antenna has worked just fine out west and I avoided having to mount the ugly one-point. Anything over 7 inches is overkill in my opinion and takes away valuable window space. You are just following a small point (or a boat icon) on a screen and not watching a movie. Get this file if you are out west.
https://www.pciraceradios.com/collec...t-hd-southwest
Robtor310 likes this.
Clockton is online now   Reply With Quote
Old 07-12-2018, 02:08 AM   #16 (permalink)
Darthyota's Avatar
I really like it. Theres more maps available for the Garmin its super accurate and I haven't needed an external antenna. Plus it has 2 video in sources so I can add a Flir Pathfinder 2 system down the riad, 2 SD card slots, it can control a Garmin action camera and once I figure out how it needs to be wired it has a J-1939 Canbus
Old 07-12-2018, 08:38 AM   #17 (permalink)
1BAD454SS's Avatar
My HDS 9 sits lower than my BAJA 5 did. I modified my own custom mount . From seated driving position, top of unit in even with right hand edge of hoodline so it blocks no window space at all. It also removable takes about a minute to loosen the knobs and and unplug the wires.
2014 FX4 Tremor 420rwhp ,2010 Raptor 6.2L 2.9 Whipple 650 hp kit .2002 Lightning 3.4 whipple 800 RWHP, 1993 454 SS 502 ci and 2.4 kennebell, 1979 10th annivesary trans am 400 4spd ,2015 POLARIS Scrambler 1000,
1995 BANSHEE ,1985 Yamaha RZ500 4 cylinder 2stroke
1BAD454SS is offline   Reply With Quote
Old 07-12-2018, 09:43 AM   #18 (permalink)
jackrook's Avatar
Yeah me and my gramps kicked around the idea of custom mounts. He has a plasma cutter so it’s easy-ish. Essentially what we are gonna do is drill into the top cubby and have to cut the brackets into an arch shape which allows us to clear the cubby. Then above the buttons(track control, flashers, etc) I’m going to use some 3M Velcro and attack a small piece of rubber that goes the full width of the Lowrance so that way on the big jarring whoops, it’s not banging into my dash, instead it’s gently kissing the rubber lol.
A.D.D front Race Bumper with 20" LED bar, Stubby antenna, Mid perch, 37" Nitto Trail Grappler MTs, Icom F5021, Outlaw Raptor Alpha 1 bed rack, M&R v2 Hood Mounts, RPG Stage 2, stock exhaust resonator delete, M&R 50" radius roof bar, K&N air filter
Check out my build thread----->http://tinyurl.com/mhdrlma
slowest member of WCPR
Lowrance gps bigbanana777 Ford F-150 Raptor General Discussions [GEN 2] 10 12-25-2017 10:08 AM
Lowrance hds-5 Peattie Garage Sale 5 02-23-2017 12:37 AM
So I got a Lowrance, now what??? goathearder Ford Raptor Audio/Video/Electronics Forum [GEN 1] 13 01-22-2015 05:06 PM
FS: Lowrance GPS 5m HD MajorAR Garage Sale 9 08-20-2014 09:06 PM
Which Lowrance GPS to get? Danactive Ford SVT Raptor General Discussions [GEN 1] 62 05-23-2014 08:40 PM
