Ford Raptor airbag/seatbelt light on
tossty
Puerto Rico
Hi, I have this problem for the last 4 days. The light came on suddenly while I was driving. Is been on even that I disconnected the battery for at least 1 hour while checking under the seats for loose connection and seatbelts. I disconnected all connections under the driver and passenger seats and sprayed some electrical connector cleaner and connected everything back again. Connected the battery and the airbag/seatbelt light came on again. My Raptor is a 2013 Super Crew USDM. If somebody had this issue before and knows what is the fix for this besides taken the vehicle to the dealer I would appreciated. My Ford dealer is about one hour drive from my location but if I have no other options I will have to make that trip to them. I did look around this forum to see if anybody had this problem before but I did not find anything. Thanks in advance for the advice.
I am including a picture of the yellow light for reference.
SZDZMTR
Sewell, NJ
aiirbag module going rogue?
---------- Post added at 08:28 AM ---------- Previous post was at 08:28 AM ----------
aiirbag module going rogue? can you scan it?
Deleted member 12951
Because you disconnected the module for the seat belt that is causing this. I did the same thing. I had a shop turn it off when they were doing an alignment so there is a way to do it without having to go to the dealer.
Should of disconnected the battery before unplugging under the seat.
WRCRaptor
Great Lakes
If it was going on and off I would say it's a clock spring. On my truck it would come on after driving for a bit then reset each time I cycled the ignition. No code was stored but was traced to that clock spring. I would say it is that module the other guys mentioned.
T
tossty
Puerto Rico
Thanks all for the inputs. Found a friend that does have a scanner that checks Air Bags ans SRS system. He will stop by today to see if there is any code that we can retrieve. As a note, I did disconnect the battery and pressed the stop pedal 3 times before I took a look under the seats connections. Will post results of the scan today and hopes it find something there that I guest will be my next trip to the dealer to have that fix. My Raptor only has almost 13,000 miles but it is 3 years so I guess there is no warranty that covers that repair now.
T
tossty
Puerto Rico
As I mentioned this morning, my friend stopped by and was able to use the scanner and pulled the code. The code is B1211, Ford SRS Electronic Instrument Cluster Switch Bank Number 2 Circuit Failure. Looks the trip to the Ford dealer have to be made.
T
tossty
Puerto Rico
Update: Went today for my appointment at the Ford dealer and since my Raptor is out of warranty since Dic 03 supposedly the diagnostic would be $85.00 plus labor and parts. But thanks God there is a recall regarding my issue "Drivers Seat Belt Retractor Pretensioner) and Ford will pick up the expenses. :favorites37: Not bad for something that I knew will be few hundred dollars.
