Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 2]
Car Stereo speaker harness adapter for B&O
This is a discussion on Car Stereo speaker harness adapter for B&O within the Ford Raptor Audio/Video/Electronics Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
I can't find the thread now either here or on f-150 forums, but someone identified the speaker harness on the ...
Like Tree8Likes
Old 06-13-2018, 05:33 PM   #1 (permalink)
Default Car Stereo speaker harness adapter for B&O
I can't find the thread now either here or on f-150 forums, but someone identified the speaker harness on the B&O system and it was something really strange like an Audi or a SAAB. I also don't remember if it was Scosche or Metra or what. Does anyone remember what it was or where the thread was? Pictures attached.
BBLV likes this.
gijosh28 is offline   Reply With Quote
Old 06-13-2018, 05:36 PM   #2 (permalink)
Junior Member
I contacted Molex and they identified the male mate to this connector but it is an oem designed piece so that male side is made to mate to a pci board. I have both plugs ordered. As soon as I can confirm they are correct, I will post the part numbers. They will be plug and play but you will have to build the harness for your application.
BBLV likes this.
dhmcfadin is offline   Reply With Quote
Old 06-14-2018, 02:24 AM   #3 (permalink)
Curious what you're trying to accomplish here? Running high level signal to a processor (Fix, etc)?
2018 Raptor | SuperCrew | Lead Foot
BBLV is offline   Reply With Quote
Old 06-14-2018, 04:51 AM   #4 (permalink)
No, being lazy. I don't want to run new speaker wires.
Old 06-14-2018, 08:25 AM   #5 (permalink)
cayenne's Avatar
If you are installing higher quality speakers with an amp and ultimately higher power you should just run new speaker wire. Cross-reference the OEM wire AWG vs what power you will be running.
GONE - 2012 Silver SCrew
GONE - 2014 Roush Ruby Red SE SCrew
2017 Lightning Blue SCrew
cayenne is offline   Reply With Quote
Old 06-14-2018, 11:28 PM   #6 (permalink)
Junior Member
I can agree with OP. Running new wire through the molex connectors in the doors is a pain in the ass.
The factory speaker wiring is 18 awg and 20 awg depending on the channel. You can run 16 ft of 18 awg @ 4 ohm and 10 ft of 20 gauge @ 4 ohm before you experience any ill side effects. As long as the wire resistance is less than 5% of the nominal speaker impedance, there will not be a difference in speaker output even when using an oscilloscope. The factory wire is fine.
Wolfeman likes this.
Old 06-14-2018, 11:46 PM   #7 (permalink)
So, the front speakers I am installing are 2ohm, and the amp is rated at 200 watts into a 2 ohm load, so I guess I do need to re-wire. What gauge speaker wire should I run?
So, if I am running the 1/0 power down the passenger side of the truck, do I need to run speaker wire up the drivers side, and cross over to the passenger side for the front passenger speaker? Or can I run the passenger speaker wire with the power wire? I know you're not supposed to run RCAs with the power wire.
Old 06-14-2018, 11:55 PM   #8 (permalink)
Junior Member
I have never experienced an issue running speaker wire and power and ground near each other. 9 times out of 10, any engine noise that is heard is due to a ground issue and generally easily remedied. RCA's is a different story in my opinion.
Check out this chart. It follows the 5% rule I spoke about above. Then you can go measure your lines and see what you need.
SilverBolt and eclou like this.
Old 06-15-2018, 11:27 AM   #9 (permalink)
Except it's not about SQ - it's about proper wire size for the current being carried so that the truck doesn't catch on fire. If you add an amp, but you never "crank it" you're probably good with factory wiring. Depending upon the wattage an aftermarket amp puts out and how loud you listen to it will affect whether you need to rewire. I always err on the side of "don't burn my truck up." P=VI is a law - and so is the amount of I that a given awg size will carry without overheating.
grumble is offline   Reply With Quote
Old 06-15-2018, 01:59 PM   #10 (permalink)
Junior Member
I think itís also important to note that chart is extremely conservative. While I agree with you that with enough wattage, you can melt a wire by creating too much resistance, itís not a realistic concern at this level. He is going to upgrade anyways due to his speaker resistance being 2 ohm so itís not an issue.
SPD adapter Ericgulf Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 1 07-15-2017 08:35 PM
Light bar adapter? dtt255 Ford F-150 Raptor General Discussions [GEN 2] 2 10-02-2016 08:33 PM
Installed OEM HIDs and adapter harness, no high beams? ljn21 Ford Raptor Lighting Modifications Forum [GEN 1] 7 07-20-2015 03:58 PM
HID Adapter Harness ljn21 Garage Sale 2 09-22-2014 10:05 AM
Speaker adapter tips - cutting boards IPACA9 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 23 01-31-2013 11:53 AM
