Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 2]
AUX Switch Wires and Pass Through Wires
This is a discussion on AUX Switch Wires and Pass Through Wires within the Ford Raptor Audio/Video/Electronics Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Haven't seen this before... Is it possible to configure Upfitter Switches to be hot all the time? It IS possible ...
Like Tree26Likes
Old 09-25-2017, 11:48 AM   #21 (permalink)
WhatExit?'s Avatar
It IS possible to configure the Super Duty Upfitter Switches: Aux #5 & #6 to be hot all the time - see below:
Link to source:
https://www.fleet.ford.com/truckbbas/non-html/Q-252.pdf
SilverBolt likes this.
2017 Magnetic SuperCrew Cab 802a; Raptor Tech Pkg w/Adaptive Cruise; 17" Forged Aluminum (Beadlock) Wheels; 2nd Row Heated Seats; Moonroof; Tailgate Step; Exterior & Hood Graphics Pkgs (both removed); Carbon Fiber Pkg; Engine Block Heater. Added: new V1; BlendMount; XPEL Ultimate & Stealth Film; Tinted Front Windows; BedRug, Roll-N-Lock A-Series bed cover
WhatExit? is offline   Reply With Quote
Old 09-25-2017, 11:53 AM   #22 (permalink)
Smokeshow60's Avatar
SgtMajor of the MemeCorps
Link to source:
Very good question. Worth looking into.
Smokeshow60 is online now   Reply With Quote
Old 09-25-2017, 12:20 PM   #23 (permalink)
Where did you pass your wires from bumper to aux hot wires?
Fender is offline   Reply With Quote
Old 09-25-2017, 02:59 PM   #24 (permalink)
WhatExit?'s Avatar
If you're talking to me about running the wires from the rear bumper (2 Rigid Dually LED lights mounted under the bumper), I have not yet run the wires to the engine compartment and the Upfitter AUX wires.
I am looking at running the wires inside Liquid Tight flexible conduit (1/2") secured to/above the frame rails to keep them up out of the way. If I do this I'll likely branch a line off and run it up inside the Bed as I want to install a power panel with a Blue Sea Systems power distribution block along with a couple of 12v outlets, a dual USB charger outlet and a switch or two.
Here's what I'm looking at doing: "Power Panel" - Looking at installing in Truck Bed
Old 09-25-2017, 03:09 PM   #25 (permalink)
Yeh i was just looking at those photos, its a great combo for the back. Where did you run the harness from the front bumper to the firewall?
Old 10-27-2017, 12:43 AM   #26 (permalink)
Junior Member
Any answer to this? Iím going to be running a ton of goodies including fog lights. Any tips on running wires/harness from front bumper to AUX wires?
Dynosaur is offline   Reply With Quote
Old 10-27-2017, 12:00 PM   #27 (permalink)
cayenne's Avatar
I ran my wires inside the frame rail in cable wrap. Came right out behind the bumper. Ran a pull string using a fish stick and then pulled the wires. Was very easy and completely hidden.
WhatExit? likes this.
GONE - 2012 Silver SCrew
GONE - 2014 Roush Ruby Red SE SCrew
2017 Lightning Blue SCrew
cayenne is offline   Reply With Quote
Old 11-01-2017, 07:52 PM   #28 (permalink)
ckelly33's Avatar
Junior Member
How do you open the kick panel? Just pull??
ckelly33 is offline   Reply With Quote
Old 11-08-2017, 06:19 PM   #29 (permalink)
KryptosXLayer2's Avatar
Link to source:
As you're aware, this is for the Super Duty's, not the Raptor. I can't seem to find any upfitter fuse box separate from the main one, and none of those have this dual-position 5A fuse that turns #5 and 6 to hot all the time. I found a video but I'd rather not modify any of the switches directly if I can avoid it:
https://www.youtube.com/watch?v=YIs3pooPmjc
There has to be an easier way like the diagram you described to get constant power to upfitter switches in the Raptor. I'm going to be installing warning lights (amber / white) and they need to be able to be left on when the truck is off, and walk away when parked.
Any other thoughts to this?
2017 Avalanche Grey / Orange Accent Interior SuperCrew, let the fun begin! View my Window Sticker
Raptor Assault Alumni 5/21/18!
KryptosXLayer2 is offline   Reply With Quote
Old 11-08-2017, 10:07 PM   #30 (permalink)
WhatExit?'s Avatar
Someone may be able to show you/us a way to run power to one or more of the Upfitter Switches all the time (unswitched power).
If I were you I'd consider running a separate switch(es) for your lights. I'm thinking of doing that anyway in addition to the Upfitters as I'm pretty certain I'll need/want more switches. There are numerous aftermarket products that can be used and there are also many online tutorials on how to create switch panels with relays, etc.
Tags
aux, upfitter, wires
Pass through wires pat247 Ford Raptor Lighting Modifications Forum [GEN 1] 12 02-17-2016 07:19 PM
Where to pass wires from engine bay to glove box/Cabin Fb73 Ford Raptor Problems and Questions Forum 9 02-13-2015 01:03 PM
Pass thru wires IRONMAN Ford Raptor Audio/Video/Electronics Forum [GEN 1] 17 08-03-2012 06:46 PM
How To Ford Raptor AUX Switch Pass-Through Wires BIRDMAN Ford Raptor How-To's and FAQs 2 01-16-2012 02:26 PM
Pass Thru Wires / Upfitter Switches Explained (Video) BigJ Ford Raptor Audio/Video/Electronics Forum [GEN 1] 24 07-23-2010 10:13 PM
