Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 2]
Add a sub problem
This is a discussion on Add a sub problem within the Ford Raptor Audio/Video/Electronics Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
This is why I was suggesting a multimeter. You need to check if your voltage is dropping or even stable....
Like Tree2Likes
Old 05-13-2018, 09:10 AM   #31 (permalink)
smurfslayer is offline   Reply With Quote
Old 05-13-2018, 09:45 AM   #32 (permalink)
Junior Member
I checked it but when I checked both positive/negative, it wasn’t under load.
sherwood is offline   Reply With Quote
Old 05-13-2018, 06:20 PM   #33 (permalink)
I wouldn’t have suspected either power or ground, but when I pulled the ground cable, many of the strands had frayed and broken off. lesson learned.
multi-meter positively id’d the problem as drop in voltage and giving the amp and sub clean power corrected the issue.
Old 05-14-2018, 09:49 AM   #34 (permalink)
The Car Stereo Company's Avatar
aka nosbusa
what wires are you usng to go to the lc2? also try removing the lc2 from the system
its not how fast you can go......its how fast can you get to fast......
The Car Stereo Company is offline   Reply With Quote
Old 05-16-2018, 05:15 PM   #35 (permalink)
Junior Member
I've tried going from iPhone to 3.5mm to RCA for amp inputs (taking LC2 out of system) and still had the same results.
Old 05-16-2018, 08:28 PM   #36 (permalink)
we’re several pages in, so let’s level set, shall we?
OP:
the recommended Pioneer 8" sub with Kenwood amp in my 802A B&O system. I used an AudioControl LC2i line converter to get the signal from the existing amp, convert to RCA inputs, then to new amp to power the Pioneer sub. I hooked it all up as other members have and there is lots of distortion and sounds completely terrible. I've rewired the whole system multiple times (changed dual voice coil series/parallel, changed speaker wire inputs, checked positive/negative amp connections, different line converter...) and still coming up empty. While the speaker is out of the enclosure, there is no distortion but as soon as it's in the box, the distortion comes back even at low levels.
So, my question is if people had to modify the existing box (other than moving plastic to fit speaker)? Did other people drill ports? Why is speaker distorting when mounted?
Have you removed the line converter and reverted to simple splicing to RCA inputs? @Toadster’s blog, and the F150 forum post detail this method.
here’s what know: your method didn’t work. Everyone else who’s done the sub mod has worked. what’s different?
also, did you get a mutimeter read out while the sub / amp was under load?
I’m not trying to make this personal here, just illustrate that this is a mod that literally dozens of us have done successfully. I even offered the troubleshooting I did to find the bum ground.
can you get some pics showing your setup? We’re kind of shooting in the dark without a light here.
if pics and the multi-meter and subsequent troubleshooting is going to be too much of an ask, bite the bullet and take it to pros.
Could not cost more than $300 to fix this. If your time is more valuable, it may be best to go this way now, before you fry something.
Old 05-16-2018, 10:40 PM   #37 (permalink)
Junior Member
OP:
I just hooked amp straight to battery positive/negative and used inputs from phone to RCA. Same result. I’m sure I’m screwing up but I've rewired and tried every combination but I'm hours in now without change.
My main question is that so far it seems everyone doing this mod is 2017. Anyone with 2018 B&O do this?
Video is setup as stated (yes I know speaker is not screwed in but previous tests show same “sound” regardless).
https://youtu.be/7Ul0I_jD9fw
Old 05-17-2018, 12:50 AM   #38 (permalink)
Junior Member
There’s not much to wiring but here is the pic. Red- battery positive
Black - battery negative
Missing is remote switch but was connected (amp was powered up)
Input is from rca to phone (also missing to take picture)
Speaker hooked up 4 ohm per instructions and confirmed with multimeter.
Old 05-17-2018, 10:43 AM   #39 (permalink)
what gauge wire are you using to power the amp?
---------- Post added at 10:43 AM ---------- Previous post was at 10:35 AM ----------
hmm... is there a 2018 issue ?
Now there is interface for the B&O system
Old 05-17-2018, 05:14 PM   #40 (permalink)
Junior Member
When hooked straight to battery it was either 12 or 14 gauge but when hooked to inverter power was 0 gauge.
I really think it’s the 2018 enclosure with weird port tube causing the issue.
OEM HID Problem PeytonW1313 Ford Raptor Lighting Modifications Forum [GEN 1] 13 04-13-2018 08:44 PM
4wd Problem? RaptorScrew Ford Raptor Problems and Questions Forum 4 03-16-2015 11:01 AM
Cut-out problem? moonjim Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 1 06-23-2013 06:22 PM
Need help with a problem! CSmith Ford SVT Raptor General Discussions [GEN 1] 6 07-29-2012 05:29 PM
Does anyone else have this problem? BIGt0007 Ford Raptor Problems and Questions Forum 12 04-27-2012 05:51 PM
