Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
Who is running a trail light?
This is a discussion on Who is running a trail light? within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
I'm looking at the Baja S2 with a yellow lens as a rear racing bed light. Anyone have any thoughts?...
Like Tree17Likes
Old 08-03-2018, 05:55 PM   #1 (permalink)
DrifterGTR's Avatar
Default Who is running a trail light?
blk91gt likes this.
Any road followed precisely to its end leads precisely nowhere. Climb the mountain just a little bit to test that it's a mountain. From the top of the mountain, you cannot see the mountain.
DrifterGTR is offline   Reply With Quote
Old 08-03-2018, 06:32 PM   #2 (permalink)
zombiekiller's Avatar
when it is REALLY dusty an S2 isn't really enough in the daytime. This is especially true if it is a mid-speed (think 15-30 mph) run on a tighter trail.
At very least if you go S2, go with a Pro(s).
I run a pair of squadrons and a pair of S2s as chase lights.
zombiekiller is offline   Reply With Quote
Old 08-03-2018, 06:59 PM   #3 (permalink)
trophycummins's Avatar
Five years ago, every truck in dezert racing was running semi truck marker lights as a dust light.
I personally feel that a pair of S2 pros does a great job as a dust/trail light. Just make sure you mount them as high as possible.
A.I.I.Raciing likes this.
Tim @ Galpin Auto Sports - Los Angeles, CA
95 Ford Bronco w/ Solo motorsports long travel and cage in progress.
2017 F150 With Mid Travel and King 3.0 coilovers/bypasses. SVC Bypass rack/King 2.5 bumps/Deavers/Camburg shackles.
trophycummins is offline   Reply With Quote
Old 08-03-2018, 07:14 PM   #4 (permalink)
The S2 makes for a great dust light. We use them in our third brake housings and they are bright as hell.
NE Ford is online now   Reply With Quote
Old 08-04-2018, 02:42 PM   #5 (permalink)
Junior Member
Can you get more shots of your setup here? Is the GPS puck mounted on the light? Very clean set up. More details please...
t_j likes this.
Jsousa03 is offline   Reply With Quote
Old 08-04-2018, 02:44 PM   #6 (permalink)
https://gj-motorsports.com/Lighting/GJ-Motorsports-3rd-Brake-Lights/Ford-F-150-Raptor-2010-2014-3rd-Brake-Light
GPS puck in mounted to the roof but we can add an antenna mount to the brake light housing.
t_j likes this.
Old 08-04-2018, 03:03 PM   #7 (permalink)
Here is a good night-time comparison shot. The decision is ultimately yours.
The lights from top to bottom:
2 S2 Sports, work/scene lens in GJ motorsports 3rd brake light housing. (yellow)
2 Squadron Sports, wide/cornering lenses (yellow)
2 S2 Pros, Wide/cornering lenses (White)
you can see that while S2 Pros are brighter than S2 Sports, Squadron Sports are much , much brighter by comparison. I have been in heavy dust on runs where it is sand 2 track with trees on both sides ( during the day in bright sunlight), none of the 2 light combos are blinding to the follow truck. The Squadrons are much easier to see when the trucks are spaced 30-50 yards apart.
I have the s2 sports and squadron sports wired to a flasher as well, for emergency/caution scenarios.
I have not had them lit up on a night run yet.
t_j, NE Ford, ASD1 and 1 others like this.
Old 08-07-2018, 01:08 PM   #8 (permalink)
Nice !!
Any day photos that show how the lights are mounted to the rear bed rail?
Does the bed rail light work well for reverse lights or does the tail gate get in the way / block the light pattern?
blk91gt is offline   Reply With Quote
Old 08-07-2018, 01:20 PM   #9 (permalink)
Clockton's Avatar
You want your chase lights to be at the same height and as high as possible. If you run lights at different heights, you could look like two different trucks from the rear. People who race will ding you for multi-level chase lights.
Clockton is offline   Reply With Quote
Old 08-07-2018, 01:35 PM   #10 (permalink)
I can switch all of the pairs on/off independently. I took a picture of everything on just to show the comparison.
The brakelight yellows work great for most situations, and the squadrons work best for super heavy dust.
---------- Post added at 11:35 AM ---------- Previous post was at 11:33 AM ----------
Originally Posted by blk91gt View Post
Nice !!
They are mounted to the top of the bedrail. I unbolted the bed , slid it back a couple inches, then tightened them down. They are on top of the rail, so the tailgate doesn't come into play. I also have a bedcover which doesn't block them even when it is rolled up.
Small Running light - Where to buy\how to replace? Raptor_man Ford Raptor Maintenance Forum 8 01-10-2016 01:22 PM
no light with truck running wakejunky Ford Raptor Problems and Questions Forum 7 05-12-2015 09:50 AM
Trail runninG March 7 in the PA/CT/NJ area? buffro Northeast 11 03-14-2015 08:52 PM
Trail running in CT/PA/NJ, Sat, March 7 buffro Upcoming Expedition Announcements and Planning 4 03-06-2015 12:27 PM
Trail Running JP7 Off-Roading Your Raptor 26 09-19-2011 09:17 PM
