Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
up fitter light install 2017 Gen2
This is a discussion on up fitter light install 2017 Gen2 within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Have not done any lighting cannot find any how to videos on the 2017 wiring harness. Just want to install ...
Like Tree6Likes
Old 03-24-2017, 07:05 PM   #1 (permalink)
Taube2013's Avatar
Junior Member
Default up fitter light install 2017 Gen2
Have not done any lighting cannot find any how to videos on the 2017 wiring harness. Just want to install a light bar on bumper. The owners manual says the 15 amp is the highest amperage most light bars are pulling 20-25 amp do you just simply change the fuse ? And does anyone have the steps to do the light bar wiring? I know this is pretty basic stuff I just have not yet did one any help is appreciated, taube2013
Taube2013 is offline   Reply With Quote
Old 03-24-2017, 07:11 PM   #2 (permalink)
ZaneMasterX's Avatar
Dont burn down your truck...if you cant figure it out yourself pay someone that knows how to do it.
Relays, in line fuses, yadda yadda
ZaneMasterX is offline   Reply With Quote
Old 03-24-2017, 07:22 PM   #3 (permalink)
Aaron's Avatar
Meme Corps Commandant
Haha holy shit man don't go swapping fuses for higher amperage ones. That's how your truck burns down.
COMMANDANT OF THE MEME CORPS
MCLTW!
It is not who we are that matters....what matters is our memes...
Aaron is offline   Reply With Quote
Old 03-24-2017, 07:27 PM   #4 (permalink)
Addictive Desert Designs's Avatar
This may help you.
Addictive Desert Designs is offline   Reply With Quote
Old 03-24-2017, 07:36 PM   #5 (permalink)
Taube2013's Avatar
Junior Member
Ok good info so does anyone have walk though ?
---------- Post added at 07:29 PM ---------- Previous post was at 07:27 PM ----------
Thank you ADD so if a ridged 40 inch light bar is pulling 20amps you cannot use because you would be blowing fuses correct?
---------- Post added at 07:36 PM ---------- Previous post was at 07:29 PM ----------
Thank you ADD so a 40inch rds Ridgid light is pulling 20 amp draw you cannot use because you would be blowing fuses correct?
Old 03-24-2017, 07:41 PM   #6 (permalink)
Ironhorse07's Avatar
I am going to say that from your questions, it appears to me that you are in over your head on this deal. I would suggest finding someone who knows what they are doing to do this.
I don't half-ass anything, I fuck it all the way up.
2014 Tuxedo Black Screw, 2017 Avalanche Screw
Ironhorse07 is offline   Reply With Quote
Old 03-25-2017, 10:16 AM   #7 (permalink)
New 2017 Raptor. 70k
New Rigid 40" light bar $400
It all going up in a blaze from a DIY project. Priceless
johnjoemd is offline   Reply With Quote
Old 03-25-2017, 12:17 PM   #8 (permalink)
ISFast's Avatar
Gen 2 65 amp total compared to Gen 1 85 amp total..... hmmm but more switches in the Gen 2
Is that all?
ISFast is offline   Reply With Quote
Old 03-25-2017, 06:14 PM   #9 (permalink)
Taube2013's Avatar
Junior Member
Default Upfitter switches request for help!
Any one that's interested on this subject I found a good post that answers my questions about the light bar installation and the amperage and relays, under the Upfitter switches request for help! post thanks taube2013
Old 03-27-2017, 10:14 AM   #10 (permalink)
Guy
The answer my friend is not blowing in the wind.
You will need a hot wire going to the battery with an appropriate gauge and in-line fuse. I'd spec for 25-30 amps and go 10 gauge. Why? Because you can.
That hot wire will need an in line fuse. It'll power the incoming hot leg of a relay rated for 30 amps. You'll wire the outgoing 30 amp hot leg to the lights. You'll ground the lights to the frame. You'll wire the control hot and negative wires of the relay, one to the battery negative post and one to the hot leg of the upfitter switch.
If you don't know what I'm jabbering about... stop now and go to a reputable shop.
Guy is offline   Reply With Quote
2017 GEN2 Magnaflow Exhaust PerOrders Start NOW! [email protected] Got Exhaust 23 03-08-2018 07:38 PM
2017+ Raptor Fog Light Kits CrownOffroad Crown Offroad 9 09-07-2017 01:19 AM
Anyone install Aftermarket Intercooler on their 2017 Raptor? MadRaptor65 Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 73 03-27-2017 12:30 AM
LED Bed Light Strip install ajstar89 Ford Raptor Lighting Modifications Forum [GEN 1] 3 08-05-2013 10:43 AM
Just finished my M&R Fog Light install EatsPrii Ford Raptor Lighting Modifications Forum [GEN 1] 31 07-28-2012 01:07 PM
