Rigid RDS and Baja OnX6 ARC
azmcs
Old Pueblo
Looked around for an answer, but haven't stumbled across it yet. On our Gen 2s the indicated breakers for the Aux switches is 15Amp maximum, but the 30" versions of both of these lights list a draw more than that. What is everyone doing to wire these up safely and correctly to the switches?
Thanks all!
Deleted member 12951
You have to use a relay. So the aux switch triggers another relay to turn on the light. The wire going to the relay just to turn it on doesn't need much as in gauge wire and amp but the wire for the light will need proper gauge wire accordingly for the watt/amp of the light.
A
azmcs
Old Pueblo
Awesome. Kind of what I was thinking, but the confirmation is helpful.
I can build a bottom end or do clutch swaps all day, but the shocky stuff always slows me down!
