Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Has anyone else come across this?
My passenger side led marker light on the wheel well has suddenly dimmed to the point that it is nearly invisible Any ideas or suggestions?? Please.
Unfortunately the dealer is for sure your best bet... those lights aren't cheap. I even got the light bulb coverage on the extended warranty as some of those things are like $75 each.
Exact same issue on my 2018 this morning. Only one LED is barley visible and there is condensation inside the housing. Taking it to the dealer today, will provide an update later.
I would rather spend the $33.91 each and purchase and replace myself than take to the dealer. HL3Z-15442-K. Lamp assy, daytime running. This is the entire assembly to include the rubber grommet.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
