poyndextr
For those of y'all that used the BD wire harness kit to connect squadron or S2 with the upfitter switches, how did y'all run the wires?
Did you run back along the frame, following the brake line toward the rear of the passenger wheel, then up and behind the fuse box? Or did you run between the motor and the battery taking the shortest possible path? If the latter, when you got to the frame, did you run along the inside or outside?
My first thought was I should take the most direct path and zip tie to other wire harnesses along the way. However, I think I'll end up with quite a bit of slack to manage and want the install to look as clean as possible.
What did you do with the extra cables length?
Also, where did run the split from passenger to driver side?
Lastly, where did you attach the ground? Is it okay to ground to one of the wire harness bolts? It's attached to the frame, right? One side would make contact with the nut, but the other with plastic...
All feedback and especially pics are greatly appreciated.
Thanks!
Thanks!
