Baja Designs: General Discussion Thread - GEN 2
Baja Designs
This is a Baja Designs GEN 2 General Discussion Thread!
www.bajadesigns.com
A place to post:
-Product information
-Photos
-Questions
-Complaints and comments
Have our lights or want to know more about our products?
Please post up!
_______________________________________________
www.bajadesigns.com
ENTER: "BDForums" to save 10% + Discounted Shipping!
- Bailey, Baja Designs
Baja Designs - Ford Raptor Lighting Kits - Gen 2 (2017)
www.bajadesigns.com
Fog Pocket Kit
These kits include lights, mounts, and Raptor specific wiring. This is wired into 2 Upfitter Switches. Switch 1 - 4 Lights , Switch 2 - 2 Lights.
We offer these in 3 performance packages based on user needs and driving style. "Sportsmen, Pro, and Unlimited"
https://www.bajadesigns.com/products/Vehicle-Specific-Automotive-Kits.asp
Sportsmen - $999.95
2 - S2 Sport, Wide Cornering
2 - Squadron Sport, Driving/Combo
2 - Squadron Sport, Spot
Pro - $1,299.95
2 - Squadron Pro, Driving/Combo
2 - Squadron Pro, Spot
Unlimited - $1,424.95
2 - S2 Pro, Wide Cornering
2 - Squadron Racer, Spot
30" S8, Upper Grille Kit - $974.95
This kit includes lights, mounts, and Raptor specific wiring. This will add one 30" S8 Driving/Combo, LED Light Bar to the upper grille and plug directly into the upfitter connection.
A nice option is to tie the Amber Backlight feature into the OEM parking lights. You have clean marker lights that will line up perfectly with the OEM!
https://www.bajadesigns.com/products/Ford-Raptor-2017-30-S8-Grille-LED-Light-Bar-Kit.asp
10" OnX6 Hi-Power, Lower Grille Kit - $624.95
This include on 10" OnX6 Hi-Power, Raptor specific mount, and upfitter wiring harness. You can cleanly add 11,650 lumens to your truck with a quick and easy installation!
The Hi-Power is setup in a Driving/Combo for maximum performance over the majority of our lighting zones. Call today and save 10%!
https://www.bajadesigns.com/products/Ford-Raptor-2017-OnX6-Hi-Power-Lower-Grille-LED-Kit.asp
Reverse Light Kit - $299.95
This kit includes lights, mounts, and Raptor specific wiring. This will add two S2 Sports (Wide Cornering) near the exhaust tips and will be hooked into the OEM wiring in the rear.
You get a much brighter setup than stock with only +1.8 amps additional draw!
https://www.bajadesigns.com/products/Ford-Raptor-2017-S2-Reverse-Light-Kit.asp
www.bajadesigns.com
www.bajadesigns.com
That Dude
www.bajadesigns.com
A place to post:
-Photos
-Questions
Please post up!
We are currently working on our Gen 2 Lighting Kits! What would you like to see for the Gen 2 Raptor?
Post up!
Current Projects:
- Fog Pocket Kit
- Behind the Grille, LED Lightbar Kit
- Dust/Reverse Light Kit
- And More!!!
________________________________________________
This is for GEN 2 Raptors, For GEN 1 see below:
http://www.fordraptorforum.com/f81/baja-designs-general-discussion-thread-41265/
Fog lights please and thank you!
Baja Designs
Baja Designs
Teaser Shot! Ford Raptor - Gen 2 - S8 30" LED Light Bar, BTG
Lighting Shown:
S8, 30" LED Light Bar, Driving/Combo
Package:
https://www.bajadesigns.com/pc_product_detail.asp?key=3AFE9887B1F0462A8F19670F4C460226
your list has me covered...for now. Most interested in LED fog lights kit for stock bumper pockets.
fog light pods bracket and a maybe a s8 behind the vent in the bottom of the grill...
Would purchase fog lights kit for stock bumper pockets right away.
Thanks for posting up! We are looking at a mounting system that will more than likely incorporate the following:
*NOTE: This is just a prototype. Production options may vary
- (4) Squadron Series, LED Auxiliary Lights (HERE)
- (2) S2 Series Lights, LED Auxiliary Lights (HERE)
- Can Mix and Max 6 Squadron/S2 Series Lights. (3 Per Side)
EDIT: SEE OP FOR KIT LINKS
-Bailey, Baja Designs
Seartrip
BD-
Glad to see you working on this. I've definitely decided your lights are what I'd like to use. Just sharing my thoughts for what they're worth:
- I want to see the fog pocket kit and may go that route when a kit is available. However, I find myself really liking those pockets open for some reason, so I've been hoping to see some other type of low profile/minimalist bumper light mount as an option. At least for me, I don't want to add an aftermarket bumper that weighs more and changes the looks that much (admit they look great though- ADD, Rogue, etc.), and I suspect for those with the 802A package, may interfere with the adaptive cruise control module and/or front camera view.
- As much as I'd like to have zillion lumens on the front end, for my needs I'm thinking I need a combination on-road and off-road option that isn't overkill. In this case, I was thinking a pair of Squadron Pros for off-road use, and while not street legal, another pair of S2 Pros to use on lightly travelled roads when dark or in bad weather (of course wired separately). I think for many folks it's just not practical to have a 30"+ bar mounted that they can rarely use unless they're truly off-road. A Squadron/S2-combo might cover the bases, or something similar. I've actually tried to envision a pair of both up on the top of the bumper lip and I kinda like the option.
- Behind the grill looks clean, but always concerned about output reduction, especially for the wider pattern lenses. Also, at least in my state, I'm stuck with a front plate, so I'm leery of closing more of the airflow through the grill. But it's an option I'd consider.
- Overall, I want a high/low output option that isn't over the top, and looks good.
It's always a compromise between looks, performance and cost, but I think it's great you're taking input on the forum and I look forward to seeing what you come up with. Thanks.
Baja Designs
Baja Designs
BD-
Thanks for posting up! I should have some more teaser shots up today or tomorrow morning. Our engineers are working hard trying to get these kits to be the perfect blend of looks and performance.
- I definitely know what you mean about the open style pocket. With this option you can have anywhere from 1-3 Pairs of lights. Having 1 would maintain some of the open look.
- The nice thing about having different kits is it gives you a variety of different options for lights based on your needs. For example, you can have one pair of Squadron Sports in Wide Cornering as Fog Lights. When aimed correctly they are our most "Street Friendly" Lights. We will be offering an S2 Sport soon so that might be a great option for you! :biggrin:
- Mounting the light behind the grille will reduce the output slightly. A big plus of having the lights tucked away is the theft deterrent. They aren't so noticeable back there and it will take some time to try to break them out.
- Using our OnX6 Series Light Bars you can have a High/Lo functionality. The OnX6, OnX6 Racer, and OnX6 Hi-Power have a built in dimming feature. While they don't dim enough for street use, it is very nice for poor weather conditions or situations with lots of glare
Teaser Shot! Ford Raptor Gen 2 - Lighting Packages:
- 30" S8, LED Light Bar, BTG (HERE)
- (2) S2 Series Lights, LED Auxiliary Lights HERE)
- 10" OnX6 Hi-Power, Lower Grille (HERE)
*NOTE: This is just a prototype. Production options may vary. Raptor Specific Kits COMING SOON
