GEN 2 6 2” cube lights to aux 2????
troycrna
Getting ready to instal 6 rough country 2” X5 cubes to the bumper cut outs. I’m pretty much electrical stupid! Is it ok to put them all on aux 2. I want the ability to turn them all off and on with one switch.
nick71692
To be safe I wired them outside to inside on 3 switches...if you dont plan on running a ton of lights I wouldnt load them up. My outside two are on switch #6, the next two #5, and the remaining 2, #4.
Plus running all three together is bright and its nice to have the option on country road to just throw on two or 4 of them versus all 6 at once.
COBRA90GT
HOCKEYTOWN ® MI
It's not rocket science, just add up the total number of amps from the lights and determine if it comes close to exceeding the max amp rating for the particular circuit (upfitter number switch) you wish to wire/hook into.
Does the box/instructions/specs list the amp draw for those specific lights ?
A quick google search revealed this btw (not sure if same ones?):
2-inch Square Cree LED Lights (X5 Series) [76903] | Rough Country Suspension Systems®
A "4amp draw" is listed for the lights down below in the Q&A section with the manufacturer FWIW...that should get you started.
