Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
2017 M&R Ford Raptor Gen2 Dual 40" kit
This is a discussion on 2017 M&R Ford Raptor Gen2 Dual 40" kit within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Yes I know they are backwards. I still need to swap them....
Like Tree47Likes
Old 01-01-2018, 02:31 AM   #81 (permalink)
2017 Lightning Blue SCAB ordered 1/3/17
Micha is offline   Reply With Quote
Old 01-01-2018, 03:02 AM   #82 (permalink)
What other if any wires do I need to complete this install? Wanting to put each bar on its own upfitter switch in truck
Cdcorn1 likes this.
Edit Signature Here
Msb.19d is offline   Reply With Quote
Old 01-01-2018, 04:02 AM   #83 (permalink)
Just some red and black 16 gauge wire. I put mine on switches 3 and 4 by themselves.
Old 01-01-2018, 09:31 AM   #84 (permalink)
Any reason you couldn’t run both on the same switch? Can one switch handle the load?
SpeedJunkie is offline   Reply With Quote
Old 01-01-2018, 10:29 AM   #85 (permalink)
jdubub's Avatar
#AllRaptorsMatter
Originally Posted by SpeedJunkie View Post
Any reason you couldn稚 run both on the same switch? Can one switch handle the load?
I have both of mine on switch 1 via a relay.
I have all 6 of my cubes on switch 2 via a relay.
I知 trying to figure out how to wire my girl when she is in the truck to switch 3, closing her mouth. When I have that figured out I will report back.
- 2017, 802A, Carbon Fiber & Technology Package, Meant to be as it was Built on my Birthday, 5% Tint, Escort 360 on Blendmount, Nitto Ridge Grapplers, Methed NV's, Amsoil, Bakflip G2, SPD Turbo Adapters, Leveling Collars, 6 LED Cubes, Forscan Mods, M&R Dual 40" LED, More to come....
2014 Sold
jdubub is offline   Reply With Quote
Old 01-01-2018, 11:19 AM   #86 (permalink)
I知 a relay newbie, so this is probably a dumb question and I知 using poor terminology, but is the purpose of the relay so you can run power directly to the battery and then use the AUX switch to trigger the relay?
If so, did you put a fuse in-line with the battery power at all?
If you figure out the girl definitely report back!
Old 01-01-2018, 12:54 PM   #87 (permalink)
thats good light output! Does it come with bezels and wiring
cain072567 is offline   Reply With Quote
Old 01-01-2018, 06:38 PM   #88 (permalink)
jdubub's Avatar
#AllRaptorsMatter
Yup, you are correct. I used some old wiring harnesses from past lights, so the fuse was already built in. You can wire one up just as easily, without the harness, but I would definitely go ahead and use an inline fuse just as a CYA.
2014 Sold
Old 01-01-2018, 07:40 PM   #89 (permalink)
Any particular type of fuse and rating?
Old 01-15-2018, 08:00 PM   #90 (permalink)
Do you have to take the grill off to install, or can you do it without removing it? Are there install instructions or a video somewhere on the install?
2018 Black Supercrew 802a w/Factory Beadlocks - Bedrug : Bakflip MX4 : Locke'er Down : BD Triple Pro Fog
Sold:
2014 Black Supercrew - Roush Factory Supercharged
2012 White Supercrew
torrin is offline   Reply With Quote
Tags
2017 raptor, 2017 raptor led, gen2 raptor, raptor 40"
up fitter light install 2017 Gen2 Taube2013 Ford Raptor Lighting Forum [GEN 2] 12 04-14-2017 10:11 PM
MagnaFlow Black 3" Dual Split Rear Exit Cat-Back w/5" Tips for 2017 F-150 Raptors CJ Pony Parts CJ Pony Parts 0 04-05-2017 08:05 AM
Gibson 3" SS Dual Rear Exit Cat-Back w/5" Polished Tips for all 2017 Raptor F-150s CJ Pony Parts CJ Pony Parts 0 03-31-2017 10:01 AM
2017 M&R Ford Raptor Dual 10" Lightbar kit MandR Automotive Ford Raptor Lighting Forum [GEN 2] 2 03-18-2017 01:39 AM
GEN 2 "First 2017 Ford Raptor Prerunner" WhatExit? Ford F-150 Raptor General Discussions [GEN 2] 24 01-06-2017 09:58 PM
