2017 M&R Ford Raptor Gen2 Dual 40" kit
MandR Automotive
MandR Automotive
Another extremely satisfied customer all the way in Panama. Dual 40s kit as well as the fog kit.
Pankster
I just got everything mounted. My question is what do you recommend me using if I want to wire each of these to my upfitter switches and it will exceed the amp rating. I would use 5 and 6 which are only rated at 5 amps. I know I need a relay but not sure what to buy......a link to what I need would be helpful.
Thanks
MandR Automotive
MandR Automotive
You would put a relay and a new power cable with an inline fuse and let the aux switch just turn on the relay
---------- Post added at 03:11 PM ---------- Previous post was at 03:11 PM ----------
Post up pictures
Thanks
https://www.amazon.com/dp/B0002KR9GG/?tag=fordraptorforum-20
or
https://www.parts-express.com/12-vdc-automotive-5-pin-relay-spdt-30-40a-bosch-type--330-073
I think both bars should be ok on a single up fitter wired with a relay. You might think 1 switch per light now, but they get used up quick.
Pankster
Waiting on my relay but I had upfitter 4 available so I used it. These lights are very bright! Very satisfied with the product. Knocked it out in about 3.5 hours, took my time so I didn't break anything....lol
Pankster
All done! Install wasn't bad at all!
