Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Lighting Forum [GEN 2]
2017 M&R Ford Raptor Gen2 Dual 40" kit
This is a discussion on 2017 M&R Ford Raptor Gen2 Dual 40" kit within the Ford Raptor Lighting Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Like Tree44Likes
Old 03-20-2018, 10:09 AM   #111 (permalink)
Originally Posted by DDSING View Post
Installed this afternoon. Install went great and didnít have any issues. After getting everything wired up I got a CEL. Any thoughts as to what could have caused this? Thinking maybe a air shutter error or something since all of that came out for the install. I havenít had a chance to run the code yet.
I know when I took the grill off there were a couple different wiring harness plugs you had to disconnect IIRC. Did you make sure to plug them all back in?
SpeedJunkie is offline   Reply With Quote
Old 03-20-2018, 11:34 AM   #112 (permalink)
Junior Member
I believe I plugged everything back in but I may have to pull that top cover back off and double check. The 3 lights in the grill work so at the very least I remembered to plug those back in.
DDSING is offline   Reply With Quote
Old 03-20-2018, 03:48 PM   #113 (permalink)
Is there a Gen 1 set up for the double light bars.
Gatica is offline   Reply With Quote
Old 03-21-2018, 10:53 AM   #114 (permalink)
Junior Member
I moved my ground to the negative terminal on the battery and the CEL went away. Not sure why but it seemed to have fixed the issue.
Old 03-21-2018, 08:52 PM   #115 (permalink)
There is a setup but it's a 40" below the ford sign and and a 30" above the ford sign
MandR Automotive is offline   Reply With Quote
Old 03-22-2018, 03:39 PM   #116 (permalink)
Im interested PM me a price 30 amber and 40 white with hardware and wires
"Life is not measured by the # of breaths we take, but by the moments that take our breaths away"
Old 07-09-2018, 04:20 PM   #117 (permalink)
Junior Member
Default White/white vs white/amber
Any feedback on which setup you like better and why? I had all white on my last raptor and Im not sure how often I would use the amber vs the white. Any feedback from guys who have the setup would be appreciated...
rage27 is offline   Reply With Quote
Old 07-12-2018, 06:29 PM   #118 (permalink)
I have all white. I haven't tried the amber, but personally I preferred the look and the light output of all white over amber.
I also have the Ford Raptor Lights kit with the amber KC flex lights in the fog pockets, so I didn't feel like I needed more amber anyway.
Light output on the M&R is very bright. I also like the subtle look with them being behind the grill. Build quality is excellent. I am very happy with mine.
Old 07-13-2018, 05:41 PM   #119 (permalink)
Junior Member
Thanks for the input...I ordered the white/white as well
Tags
2017 raptor, 2017 raptor led, gen2 raptor, raptor 40"
up fitter light install 2017 Gen2 Taube2013 Ford Raptor Lighting Forum [GEN 2] 12 04-14-2017 10:11 PM
MagnaFlow Black 3" Dual Split Rear Exit Cat-Back w/5" Tips for 2017 F-150 Raptors CJ Pony Parts CJ Pony Parts 0 04-05-2017 08:05 AM
Gibson 3" SS Dual Rear Exit Cat-Back w/5" Polished Tips for all 2017 Raptor F-150s CJ Pony Parts CJ Pony Parts 0 03-31-2017 10:01 AM
2017 M&R Ford Raptor Dual 10" Lightbar kit MandR Automotive Ford Raptor Lighting Forum [GEN 2] 2 03-18-2017 01:39 AM
GEN 2 "First 2017 Ford Raptor Prerunner" WhatExit? Ford F-150 Raptor General Discussions [GEN 2] 24 01-06-2017 09:58 PM
