GEN 2 10" light bar for fogs
CFIT
Valencia, CA
6dd0e7a79e4b2cc0bc6666932e061186.jpg3906520eb0d9258a46d37b40a64faa7f.jpg13912ca323418f6016277dc05f722812.jpg
---------- Post added at 12:26 AM ---------- Previous post was at 12:25 AM ----------
Wiring tomorrow. Thoughts?
They look great. I'm curious what the light throw is like. Given the angle of the pockets, it looks like the light may throw diagonally off the corners rather than straight ahead.
Deleted member 12951
Think it looks really good, better than I would of thought. Even if angled, would be good for side lighting.
Post of pic of just the amber backlight on with the rest of the ambers on, think it will look great.
Thanks for the order and glad it worked out great for you. I sent your pictures to my rep at Baja Designs. :)
J
johnjoemd
https://instagram.com/p/BSxQtUGFo_Mk-6wUY3fRyfkYyuVXWwym4GNAno0/
This work?
Ambers only.
---------- Post added at 03:17 AM ---------- Previous post was at 03:12 AM ----------
Definitely ditch lights. This is what I was looking for from the fogs though. I will post some lights pics later when I get them. Really like the ambers. Match the truck perfectly. Now I need a 30" lightbar behind the grill. Any deals? Haha
R
Rick@FreedomMotorsports
This work?
Ambers only.
IG link isn't working for me. Yep, Baja Designs makes an Upper Grill kit for that need, send me a PM for a quote. :)
That last pic shows them recessed a ways into the bumper, I suspect you’ll lose a little throw there. I’d say the implementation looks pretty clean. If they light up like you want, take yes for an answer.
If you go behind the grill, M&R just announced a 2x 40” kit for not bad money.
I think you’ll lose quite a bit from behind the grill though. I put 2x 2 row 17” behind the grill. Good, but you can definitely see you’re eating up some lumens there.
check the posts on this subform
Baja Designs
This work?
Ambers only.
Looks great! I would recommend changing out the lenses from Driving/Combo to a Wide Driving pattern. The Wide driving will be much better for cornering or ditch lighting with the very wide, smooth, horizontal pattern. We have lens kits available for you to easily make the change.
S8, LED Light Bar, Wide Driving Lens Kit
https://www.bajadesigns.com/products/s8-wide-driving-lens-kit.asp
$14.95 ea ------ $29.90 (QTY:2) ------- $26.91 FRF (800)422-5292x114
We also offer a 10% Discount to forum members who are looking to buy any Baja Designs (BD) product.
This will bring the 30" S8 Grille Kit from $974.95 to $877.46 30" S8 Driving/Combo, Mounts, and Upfitter Wiring are all included in the kit.
https://www.bajadesigns.com/products/Ford-Raptor-2017-30-S8-Grille-LED-Light-Bar-Kit.asp
Nicely done on the install! If you don't want to order direct, we have many great authorized dealers on the forum! Let us know if you have any questions.
Thank You,
Bailey, Baja Designs
www.bajadesigns.com - (800)422-5292x114 - [email protected]
J
johnjoemd
Swapped out to wide cornering lenses for the S8 10" fogs. Images really don't do it justice. Now they are not just perfect ditch lights. Also throwing light forward. I still have them mounted in the same position as above. Great idea BajaDesigns [emoji1417]
---------- Post added at 01:54 AM ---------- Previous post was at 01:53 AM ----------
Lows only, lows and fogs, fogs only
