Quaesta
- Joined
- Jun 13, 2018
- Posts
- 632
- Reaction score
- 402
Do you guys think the perch affects the ride or any of the safety features?
I was planning on going with your 20" VR-601 with the 35” KO2 and the RPG 1.5. What issues can I expect?
What he is saying is that if you get an aftermarket wheel with a positive offset (+6 in my case) you will get some amount of rubbing at full lock even on the factory KO2 tire. A perch of some kind will be required to eliminate it. Expect more rubbing with an even larger tire.
Yes, read some of the threads on the perch collars. The pre-load changes the ride quality and the higher you go, the more it changes.
Not sure what you mean by the safety features?
Nick,
What do you mean you may have some running with factory tires/stock 35’s? Are you talking about true 35’s as opposed to the 34’s it comes with?
