Tailgate doesn't sit flush
H
hewster
Virginia
Then remove and replace your tailgate. Mine is fine with a retrax.
Well that's what I am asking. It really has nothing to do with the retrax, it is just when I noticed it (I never looked at it that hard before).
Curious if anyone knew an easy way to somehow adjust it, or if it is somehow normal, or if my shit is jacked up
Ltl6pack
Cheraw SC
You just need to loosen the Torx stud on the left side and move it in toward the cab about a 1/16 of a inch, tighten, and close the tail gate, if not close enough, loosen and move again. mine was move on the right side from the factory about a 1/16, gate fits flush on both side, ( you can see where the paint line was, is how I know it was moved.)
Ggh1969
My drivers side has to be slammed in order to shut completely. If it's just pushed closed there's a little offset. I was thinking it's just mine but apparently it's an issue. Nothing major. Just shut it a little harder.
Nogard
Washed my Scab yesterday and sure enough, mine has a small gap on the drivers side tailgate as well. Passenger side is flush. I may have never noticed without reading this post.
Bigbo076
Winslow AZ
Same here. Gap 7mm on the passenger side, 12mm drivers side.
Check that the rubber stopper is turned the same direction as the passenger side, mine was the same and all it took was turning the stopper to fix it.
miula
Miami, FL
Can you post a pic of which torx stud you are referring to? the black one towards the top where the gate latches or the painted torx bolt on the bottom where the gate hinge is?
93,145
56,419
TwistAir
