Rear appliqué removal
Mkarban
Minnesota
Anyone know how the rear appliqué attaches? I looked at the Tasca parts site and it doesn’t list any clips. Before I try to pry it off, I was wondering if it’s screwed on or has plastic retention clips? If anyone has a pic of the back, that’d be awesome!
Thanks
MK
M
Mkarban
Minnesota
I’m keeping it. Just wanted to remove it to vinyl wrap it. They sell replacement appliqués, so if it’s damaged it can be replaced.
venomblue22
Elburn, IL
there is 24 retainer clips holding it on. take the inside access panel off, there will be to nuts under that and then access as many of clips as you can from the back side with a pair of needle nose pliers, just enough to get the applique to lift up. Once its lifted up you should be able to get a pick tool on each of the remaining clips from the outside, use the pick tool to unclip both sides of each individual clip, good luck, its a bitch, but doable
HotLap
SoCal
I did find this pic, believe it's from a KR or Platinum though, but should be very similar attachment points...
