OEM Beadlocks
Iochd
Question – Can you remove the beauty rings on the 2017/18 OEM capable bead lock rims and simply place the OEM bead lock rings in its place i.e. with tire still between rim lips – or is the bead lock ring substantially thicker than the beauty ring and would then leave a gap between the ring and the tire wall.
The Raptor I am waiting for has these rims and I prefer the look of " real " beadlock and DOT legal
kpg81
SoCal
You need the Ford Performance beadlock trim kit.
I
Iochd
Yes I know, but I believe that the thickness of the beadlock ring/ rebate for fitting into the rim would result in a gap between the ring and the tire wall once fitted
Crash33
The beadlock rings stick out about 1/2 inch further. Would look dumb.
Pacific Wheel
Reno, NV
Has anyone done this?
If they did it probably didn't last long. There would be a huge gap where the tire is supposed to go and would look pretty funny
Booth9999
Idyllwild
I held it up when I got my rings and it would look super dumb. Looks worst than the pics show forsure.
sher-bant
I have a question...
Do you know if the OEM beadlocks (came with my 2017 Raptor) would fit on my old 1997 f150?
I'm pretty sure thats a no-go.
tobywan
Powdercoated Beadlock Rings
Hey guys!
I ordered the Ford beadlock rings and they arrived this week. These rings are SWEET! I had them powdercoated, and got two mounted this evening. I left the inner bead set, so I'm hoping I am still balanced. Not too tricky of a process, just time consuming.
With the lug nuts and center caps painted flat black, I think this looks SO good. I'll take some more outdoor shots tomorrow.
Peace,
Toby
