License plate relocation in 5 minutes
ChevTillNow
PNW WA
Drilled 2 holes and used all of the original hardware took 5 minutes. Still pretty visible.
Wow! I think this looks about as good as it can for us "lucky ones" that have to run a front plate...
And this would work Wonderful with a Oynx center light in the Bottom Grill... thanks for experimenting!
I think you saved me 90 bucks I was going to go the sto-n-sho route.
Would be nice to see exactly what you did if you got the time to take some pics
What he said. Especially watch out for those high starbucks curbs. :chewie:
:snoopfacepalm: Jay, you are totally not doing it right. You don’t just beach the truck on the drive through island and walk inside starbucks. Inside is for the peasants.
Instead, stagger the tires climbing the d/t island, mowing over any shrubbery, etc.
It’s ok to have vegetation and plant life sticking out of the undercarriage, not ok to be knocking off hard parts on the starbucks curbs.
Total rookie mistake.
@Aaron is the starbucks drive thru guru. Go to the Degobah system and seek out his starbucks mastery. He will instruct you in the ways of the Latte.
:biggrin:
NOTE: It is bad form to spill your starbucks when drop off the drive thru island onto the pavement.
