Front License Plate Bracket
Romans9
Hey guys - how do you install the front license plate bracket on the Gen 2? Been searching for a while, but not seeing a how to for the stock part. Want to make sure I'm doing it right.
Northlight
You've probably....
...figured this out by now....
My front plate came with two pop rivets...of course, you need a pop rivet tool to install them in the pre-drilled holes.
Make sure the tabs on the back of the license plate mount slip into the openings in the lower grille.
Northlight
r3run33
I did not use the front sections due to inter cooler heat etc attached to the right side bumper like the do in the middle east ones
