Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Exterior Forum [GEN 2]
Front Bumper options / pictures lets see them.
This is a discussion on Front Bumper options / pictures lets see them. within the Ford Raptor Exterior Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by ChevyChad Fab Fours here.. Do you have adaptive cruise? If so did you have to move the ...
Like Tree36Likes
Old 07-18-2017, 11:02 PM   #11 (permalink)
Junior Member
Originally Posted by ChevyChad View Post
Fab Fours here..
Do you have adaptive cruise? If so did you have to move the sensor? that bumper looks amazing!!
velociraptornips is offline   Reply With Quote
Old 07-19-2017, 07:34 AM   #12 (permalink)
ChevyChad's Avatar
Yes, I have ACC. When I first installed the bumper, I left the module off and just thought I would use normal cruise control until I installed the relocation bracket. However, I learned that even the normal cruise doesn't work either unless the ACC module is plugged in.
I then plugged it in and zip tied it out of the way to the frame rail until I could install the relocation bracket behind the grille. Even though I had the collision detection system off and the cruise set to normal in the settings, I'd still get an occasional message on the dash saying that the collision detection device was blocked.
I then removed the front light bar in the middle of the bumper and zip tied the ACC bracket there to test out and see if it would work in that location. It does. Been there for a couple weeks now while I've been testing to make sure it works. Done a couple of 300 mile trips and lots of daily driving with it there and its working great. So now the plan is to make a permanent bracket to keep it there and then cut some of the stock lower grille out of the factory bumper to fit that location on the fab fours bumper and make some brackets to hold it there as well so that it gives a factory looking finishing touch to the opening.
I measured, and there is still room to put a couple 6" long mini cube lights on each side of the ACC module behind where the lower grille will be, so I can still put lights there too if I want in the future.
2017 Lightning Blue SCREW- 802A, tech package, carbon fiber, moon roof, Fab Fours Vengeance Pre-Runner front bumper with lots of LEDs, 20x9 Fuel Vapor wheels with 37x12.5 Nitto Ridge Grappler tires, Icon 2.25" front level, Line-X bed spray, tinted windows, retractable bed cover
ChevyChad is offline   Reply With Quote
Old 07-21-2017, 02:14 PM   #13 (permalink)
Junior Member
Awesome!! Thank you for all the information.. Much appreciated.
Old 07-21-2017, 03:49 PM   #14 (permalink)
Addictive Desert Designs's Avatar
We do have a new bumper that we are releasing on Thursday...
Red One likes this.
Addictive Desert Designs is offline   Reply With Quote
Old 07-23-2017, 05:11 PM   #15 (permalink)
how much cutting are you guys doing to fit these. I saw on the rogue install video they have to remove the crash bars. I have been told that voids the warranty?? But i find that hard to believe.
Jolly89 is offline   Reply With Quote
Old 07-24-2017, 09:53 AM   #16 (permalink)
Those look badass but i wouldn't even consider cutting my truck. Is that just due to the slim profile of the bumper? There's no other way?
chi_weezy is offline   Reply With Quote
Old 07-24-2017, 11:40 AM   #17 (permalink)
We are doing our first install tomorrow, & will have an install guide with pics shortly after. The front bumper will be for sale starting on Thursday!
Yes, cutting the frame gives you a much better approach angle. Its not for everyone, but there are many raptor owners who are up for it. Here is our Race Series bumper, it is the tightest fitting, best approach angle you can get without cutting the frame. It does require our intercooler kit. As you can see, the frame is what is stopping us from tucking this bumper up even tighter. Removing the tow hooks will also help the approach angle.
Old 07-27-2017, 11:41 AM   #18 (permalink)
Junior Member
Default Stock bumper with LED Light Bar
Decided not to mess with my bumper since it has the adaptive cruise control sensor in it and didn't want to move it just to put led light bar on it. I also didn't want to drill into the bumper either. So I put an N-Fab LED light bar bracket on it and it looks great! Only had to cut two slots in the lower bumper plastic cover and that was it.
fivetexans is offline   Reply With Quote
Old 07-28-2017, 02:52 AM   #19 (permalink)
Went with the ADD Stealth R and am really happy with it. Was concerned with the ACC relocate too but it was a non-issue. ACC works perfectly in the new location and you can't really make it out unless you're looking for it.
OLI62 is offline   Reply With Quote
Old 07-28-2017, 02:58 AM   #20 (permalink)
Looks awesome. I went with nfab. Now I need to find a rear bumper that cuts some length. I can barely fit in the garage right now
Other light options for ADD Honeybadger Front/Read Bumper JetDriver480 Ford Raptor Lighting Forum [GEN 2] 3 02-23-2017 12:49 AM
Front Bumper Options Roscobe Ford Raptor Exterior Modifications Forum [GEN 1] 14 10-29-2016 10:18 AM
Bumper Pictures Bar Ford Raptor Exterior Modifications Forum [GEN 1] 146 08-14-2015 02:05 AM
M&r front bumper holes light kit pictures thread MandR Automotive M and R Automotive 11 09-10-2012 09:55 PM
SVs lets here some options. The Tank Ford Raptor Exterior Modifications Forum [GEN 1] 0 05-04-2012 04:15 AM
