Flip Your Spare?....
Northlight
Rainy night here in the Great Northwest and my wife is out with the girlfriends....so let's go to the garage....
Having been surprised once or twice over the years with a "Spare With No Air" just when it was needed most, I've taken to flipping the spares on my trucks making it easy to check tire pressure. (Tire had 42 psi in it, FYI).
On my 2018 Raptor there is a matching 17" factory aluminum wheel and full-size BFG KO2. (Previous garden-variety F-150s had a steel spare wheel with an unmatched cheapo tire).
If you haven't already looked, there is the standard crank down center cable as well as an additional cable that goes through the "T" and is bolted to the frame. I'm assuming this just adds a bit of security.
I put a couple layers of duct tape around the "T" that goes through the center of the wheel and on the face of the wheel itself to protect the nice shiny finish.
Part of this fun project is learning how to take the jack kit out and put together the correct rods to crank down the spare.....oh....then reassembling and re-velcroing it all back together under the back seat.
And the night is still young....
Northlight
N
Northlight
We do....
....carry a compact compressor.
You just can't check tire pressure without dropping the spare.
And on that wet or snowy night by the side of the road, I'd rather have a full spare than unpack the compressor and wait till it's full.
Northlight
ranger22
Tejas
Northlight
If you pull the spare first and begin airing it up while you prepare and use the jack, you will not experience much delay. But flipping the spare seems easy enough.
Ditchplains1
Trescott, ME
Northlight,
If you are considering high speed offroading, you might throw a cheap ratcheting strap around the tire to the frame to prevent it from coming loose. One of our fellow Raptor owners had it happen to him...
Eddie
N
Northlight
Ditchplains....
....thanks for the advice.
I've got a set of ratcheting tiedowns hanging around in the garage looking for something to do.
Northlight
ChevTillNow
PNW WA
It would be nice if the TPMS would monitor the spare.
Thats actually a good thought. I think I might take mine up to Discount Tire and have them break it down and put a sensor inside of it. Then I'll protect that new shiny wheel as well, cuz that's a good idea too.:biggrin:
Deleted member 12951
The GEN1 will not monitor the spare and even if you did have a TPMS in it, you would have to move it to the location and have the tool to relearn the sensors.
Will the GEN2 monitor the spare under the bed if you do install a TPMS?
