Air Compress and Tank
Ballistic
Oregon
I have been wanting to get an air compressor and tank on the truck for a while, but not sure where to mount it all without loosing the spare tire.
Anyone have pics of installs on their Gen 2s
Ballistic
Ballistic
Oregon
I feel like there is alot less room room under the gen2s compared to the gen1.
I may just order this tank and throw the truck on the lift and try and find a spot..
I just want it to all be hidden.
ChevTillNow
PNW WA
You can check this review that I saw some time ago.
Fast-forward two minute mark 1 minute... looks like a pretty cool install the way he did it. But the one posted above in the bed is pretty cool too
m.youtube.com/watch?v=qXbESVshU5g
Ballistic
Ballistic
Oregon
Good to see that you can actually get a tank to fit in that gap. Not the cleanest install but it fits..
racerjb
updated picture with painted panel and 90 degree air fitting..makes it easier for attaching hose...
plus was able to post picture in correct orientation...
This compressor with the new ARB digital gauge and fill..is awesome.. I run around 18psi in the sand and then fill up to around 38 for the road..takes only about 5 minutes to do all 4
Renomaan
Air Compressor behind right fender
I mounted a compressor under the right fender as there is ALOT of room under there and shielded from the environment with the OEM skirts.
My compressor is for Airbags so it doesnt have a tank however there was ALOT of space there. Challenging to drop the skirt off (about an hr on/off) but your real close to the Upfitter connections at the top of the fender.
93,145
56,419
TwistAir
Latest posts
