Aftermarket Wheels
Pacific Wheel
Reno, NV
Offset? Weight? 18x9?
I'll know weight when they arrive next week. 9.5 +12. So protrusion as Method.
---------- Post added at 07:45 AM ---------- Previous post was at 07:43 AM ----------
I need some help, I’m looking at 2 different wheels. One is a method 8.5 x 17 with 4.75 backspacing the other is KMC XD 9x17 with -12 mm offset. I’m going to use nitto ridge grappler tires 35 x 12.50 FYI.. how much farther will each of these stick out? I know I should be able to figure this out but I want to be sure on this before committing to buying. So plz help and thanks
Method 1.3" further than stock
XD 2" further than stock (will require some trimming depending on front lift)
JeremyFXDWG
Thank You. If you can post the weight of them when they come in that would be great.
Msb.19d
Broadway, NC
Will I be ok with the kmc hole shots -12 offset with 12.5 x35 nitto ridge grapplers with 2 inch lift in front ? I can do some beer and trimming if need
Pacific Wheel
Reno, NV
A little trimming will be needed. These will stick out 2" further than stock. Keep that in mind depending on what look you're going for.
dude1782
PHX, AZ/SLO, CA
4.5" backspacing black anodized innov8 forged beadlock wheels
