Aftermarket Wheels
Zhammy3
Quad cities, IA
Wheel sizes and offsets confuse me. So i need help on which to buy. Im looking at the 20" Fuel Rampage. I know i know its not to many peoples taste here.
20x10 or 20x12?
6 x 135mm
-44mm offset
What width of tires? going with 35's. Thought about 37's
Thanks
Pacific Wheel
Reno, NV
20x10 or 20x12?
6 x 135mm
-44mm offset
Thanks
Do 35's and level it with @svc CAS perch adjustment, you'll probably still have to trim a little depending on how high you set the front. 37's and 10's would probably need a drop bracket suspension lift. You think people get crap for running 10, and 12" wide wheels, it's 10x worse if you put a lift kit on a Raptor lol. 12's it will require a lot more trimming, even with 35's but anything is possible ;)
Zhammy3
Quad cities, IA
Planned on the CAS perch kit also. Should of mentioned it
So 20x10"
6x135
-44mm
will work?
What tire specs should i be shopping for?
Thanks
Pacific Wheel
Reno, NV
Asanti Offroad Just released a new wheel. 17x8 +25 and +00. A little on the blingy side but still nice lines and a nice cap. And the offset is good if you want to keep the wheels in stock location or stick em out. They are now in stock in both offsets
Mluis11
@CUSTOMWHEELS4U
Any info on these rotiforms? I've done a little browsing on their site, but no info on 6x135 or pricing.
Pacific Wheel
Reno, NV
@CUSTOMWHEELS4U
Sent from my iPhone using TapatalkView attachment 86453
There are some 17's in transit but not enough to cover the backorders. More are finished and in production just haven't hit the water yet. The 20's have came in on a few shipments already. What size are you looking for and what's your zip? I'll PM you a quote.
