Rear Seat-Husky Storage and Sunrise Tactical Seat Covers
hamster
Northern VA
Added Husky rear seat storage and Sunrise Tactical rear seat covers.
https://www.huskyliners.com/GearBox-Under-Seat-Storage
The Husky storage box fits nice over the OEM floor mats and has one simple strap to install. The small side was perfect for recovery bag. Seat fits over it nicely. Not much else to say.
Molle seat cover, armboard, armband, tactical, ford,
For the rear seat I wanted a seat cover just to protect the surface from the lab's claws. They don't mess up the seat back so did not need to cover. Also wanted something that the hair did not stick to. This cover is made out of black ballistic nylon. It fits great and does not move. The larger side even has a strip of velco that attaches to the carpet on the underside of the seat to help hold it in place....cleaver idea. Not cheap, but top quality! And when seat is up, you can hang bags on it. NOTE: Website says through 2016, but I contacted him about 2017 and he said there was a slight change he had taken into account so be sure to specific you have a 2017 model. Not sure what the change was.
Few pics.....
OLI62
Tampa, FL
Few pics.....
hamster, does your Husky box slide around at all? I put mine in and tensioned the strap down tighter than hell but the box still seems to slide right and left a lot. I was thinking of attaching some velcro to the box and the area under the seat it abuts to keep it from moving around. Just wondering. Thanks.
hamster
hamster
Northern VA
When I put it in the first time I noticed that. Went back and looked at closeups of Husky mats and appears those might be designed with better lip to help. But I did not want to swap mats. So played with strap to minimize left / right movement and loaded small side with about 20 lbs of recovery gear. Forgot all about it until you asked. If once I get large side loaded I see movement issues, I will add another strap or two or velcro like u suggest.
OLI62
Tampa, FL
I think you're probably right about it not moving around with weight in it. I don't want to swap mats out either. I'm going to run it with my recovery/hunting stuff and see what happens. Anyway, thank you for the feedback.
Jiman
NCR
Thank so for the pics and info.
Wish they'd make a version where the storage bin would integrate with the smaller OEM bin. It looks like you can remove the screws that hold the OEM front part of the bin and attach an aftermarket extension creating a near seamless large storage area.
Until that happens I'll probably buy the Husky.
17Jul2017 UPDATE: After some research, decided on the Du-ha. It secures by two knob bolts replacing the top screw on each side of the small OEM bin. Took a chance because IMO the pics make it look flimsy/flexy, but it's actually a stiff durable material. Been very happy with it.
talldaddy
Looks great and fits in front of the Factory inverter under the rear passenger seat. Will be ordering the Husky box??
