Glove Box
bigboy4eva
I just got my Beast (Magnetic Super Crew). I got the rigid cube lights installed, however when the guy was accessing the fuse box to connect the wiring for the aux switches he accidentally cracked glove box door where it latches onto the hinge so ling story short the gkove box door isnt latching properly, any idea how i can order a replacement part or part number or any vendors out there who have then. The dealer here is useless. See pic below
Fly5150
I don't know about the door but you get to the pre wired leads under the hood.
Bullishone
I don't get why he removed that in the first place.
Sent from my LG-V521 using Tapatalk
B
bigboy4eva
There were no cables from the up shifter AUX switches to the fuse box, so they had to unlatch the glove box door and some of the interior trim at the top near the AUX switches to connect cables from AUX to fuse box. Long story short my glove box door cracked and i would like to replace it
kdub405
Are you saying you did not have wires under hood? Sounds like they have not worked on a jenny!
Ditchplains1
Trescott, ME
BigBoy4eva,
Take that bad boy to any decent body shop and have them plastic weld the crack. They can get a pretty decent job that will require a little sanding to even it out. With all of the plastic bumper trim out there these days most body shops will be able to make it look pretty darn good...
Eddie
B
bigboy4eva
