You need a trim removal tool to slide the leather boot down. you need to go around all 4 sides.
Once that's done there is 2 screws at the front of the shift knob that needs to be removed.
Use a magnetic screw driver to avoid dropping / losing the screws.
Use the same trim tool to release the electrical plug and remove shifter.
reinstall pull leather skirt up and you are good to go
