Wilwood breaks
Is that a new kit from Wilwood? We have a kit here at the shop we got for our SEMA build F150 and was told it would not fit a Raptor. We tried to mount the rotor and the hub hole was too small.
Thanks.
Fender
Thats great to see, i was told that no wilwood kits fit the raptor.
Where did you find these? Or are you custom modifying the f150 kit?
EricM
OHIO
Since when did the Raptor have different hubs than any other F150 of the same year? The wheels interchange, and they are hubcentric- so...
That ended up just being a little too much coating on the rotor hat. Wilwood says it will not fit a Raptor due to ball joint interference. We mocked up a set and the clearance to the tie rod was tight but nothing with the ball joint.
