Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
Is there a solution?
This is a discussion on Is there a solution? within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Hey everyone, I just wanted to get some advice. I'm looking for an option that would help my payload, while ...
Like Tree3Likes
Old 11-24-2017, 07:13 PM   #1 (permalink)
Default Is there a solution?
I'm looking for an option that would help my payload, while not ruining my on road or off road manners. I don't typically haul a lot of weight in my bed, but sometimes I have to place several hundred pounds of construction material, or camping gear; and I end up with a saggy bottom.
Is this possible or a unicorn?
So far I read that airbags minimize my suspension travel, and I don't know if the 2" deaver springs would help with payload or hurt.
Thanks!!
jsrick80 is offline   Reply With Quote
Old 11-24-2017, 07:19 PM   #2 (permalink)
Hockster's Avatar
My 45ft Bluewater Party
After market springs are the only way to go. Had a set on my 2012 were fantastic
Hockster is offline   Reply With Quote
Old 11-24-2017, 07:44 PM   #3 (permalink)
MatMan's Avatar
Go deaver +3 (or more 4-5) to keep her level under load. Deaver +2 is = to stock and will result in a nose up stance under load.
Airbags are for heavy towing, and not exactly commonplace on Raptor.
MatMan is offline   Reply With Quote
Old 11-24-2017, 10:08 PM   #4 (permalink)
Thanks guys. @MatMan The problem with the leaf pack is the other 95 percent of time I would be driving around with a rake again
I can't think of anything, but was hoping for a solution that wouldn't hike up the rear end, wouldn't hurt on road or off road manners.
Old 11-24-2017, 10:39 PM   #5 (permalink)
Ditchplains1's Avatar
JSRick80,
Go for the Deavers and add drop shackles. This will add droop, reduce the height of the back end, and give you the added weight carrying capacity with the additional benefit of better ride...
Eddie
jsrick80 likes this.
Ditchplains, Montauk, NY East Coast surfing mecca...
Ditchplains1 is offline   Reply With Quote
Old 11-25-2017, 12:06 PM   #6 (permalink)
Thanks @Ditchplains1
Are you saying the +3 deavers with the drop shakle? Would this drop the back end from factory heightv or would they cancel each other out and be near OEM height?
Thanks
Old 11-25-2017, 05:36 PM   #7 (permalink)
Junior Member
I have Deaver springs in the rear with SDHQ drop shackles. Sits almost exactly stock height in the rear. I tow an 8k boat/trailer, squats a little bit nothing like it did when i had the stock leafs.
ScottB is offline   Reply With Quote
Old 11-25-2017, 06:47 PM   #8 (permalink)
JSRick80,
I have the Deaver +4's with RPG drop shackles and the RPG "RST-16" rear shock system. After 4 months there is just a slight rake; this disappears when I tow my M1102 trailer.
No comparison to stock in terms of ride; much smoother, and the faster you go the smoother the ride....
Eddie
Old 11-26-2017, 04:43 AM   #9 (permalink)
I'm interested in towing around 8k as well. Are your deavers +3 Scott?
Any other towing suspension mods other than deavers and shackles?
Jspeers89 is offline   Reply With Quote
Old 11-26-2017, 10:59 AM   #10 (permalink)
Huck's Avatar
Just get HD deavers. The +3 only adds height, not any load capacity. But they are also available in HD
Icom F5021,RPG Stg 4+ Fox 3.0 coilovers, RPG Tie-rods (modified to camburg hardware), RPG PS reservoir, Camburg 1.25" UCA's , Raptor -Retro fit '13 HIDS, Line-x preminum, Bluewater LED bed lights, Ipad mini navigation. Bubba rope. Rollx, Recon 10.5k winch synth rope, factor 55, SVC Custom acuated tower. Visions 30" xmitter extreme, 35" toyo MT, visionx 6550 spot.
Huck is offline   Reply With Quote
Tags
deaver, payload, springs, suspension
Torn CV Boot Solution SDHQJASON SDHQ Offroad Racing 9 09-14-2015 02:57 PM
My Fog Light Solution HAP Ford Raptor Lighting Modifications Forum [GEN 1] 17 11-21-2014 10:55 PM
Another under hood light solution BIRDMAN Ford Raptor Lighting Modifications Forum [GEN 1] 59 05-10-2014 02:18 AM
Ok temporary solution ? JSRAPTOR Ford Raptor Problems and Questions Forum 1 01-23-2014 07:23 AM
my ipad GPS solution jackrook Ford Raptor Audio/Video/Electronics Forum [GEN 1] 44 01-04-2014 12:58 PM
