Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
SVCOFFROAD C.A.S. Coil Adjustment System
This is a discussion on SVCOFFROAD C.A.S. Coil Adjustment System within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
My set is ordered and on the way. Looking forward to installing this setup...
Like Tree236Likes
Old 05-30-2017, 08:32 PM   #191 (permalink)
F150Feste's Avatar
An intelligent man is sometimes forced to be drunk to spend time with his fools.
~Ernest Hemingway
F150Feste is offline   Reply With Quote
Old 07-17-2017, 04:17 PM   #192 (permalink)
Ballistic's Avatar
Finally got around to getting an apportionment setup for my install. Id try it myself but i don't have a good spring compressor..
Whats everyone running for measurements?
Im wanting mine Level or a touch over level.
Is this a good starting point?
Passenger: 1 9/16th
Driver: 1 3/4"
@Raptizzle do you remember your measurements?
Ordered 8/31/16, Built: 11/19/16, Delivered 1/31/17
2017 White SCREW, 802A, Tech Pack, Tailgate Step, Heated Second Row Seats and Steering Wheel, Spray in bedliner, with Moonroof
Ballistic is offline   Reply With Quote
Old 07-17-2017, 05:10 PM   #193 (permalink)
996Turbo's Avatar
Here is mine at those measurements. It is almost an inch taller in the front. I am planning on lowering it down a little because it rides a little stiffer than I want. Also, when I hook up a trailer or load stuff in the bed it is very noticeable.
Ballistic likes this.
2016 Shelby GT350 avalanche
2017 Raptor avalanche
2017 Volvo XC90 Inscription
996Turbo is offline   Reply With Quote
Old 07-17-2017, 06:11 PM   #194 (permalink)
Ballistic's Avatar
Can you re upload somewhere else or type your measurements out?
I tow a little but all under 4k pounds right now until i get deaver springs.
Old 07-17-2017, 10:11 PM   #195 (permalink)
996Turbo's Avatar
Sitdown, Ballistic and k-rub like this.
Old 07-18-2017, 09:04 AM   #196 (permalink)
Sitdown's Avatar
Any thoughts or potential to adding a top seat plate(s) to possibly make driveway adjustments semi doable? In the end, likely still need to get out the spring compressors, but just an idea for next revision.
996Turbo and Ballistic like this.
Sitdown is offline   Reply With Quote
Old 07-18-2017, 12:45 PM   #197 (permalink)
svc's Avatar
svc
Trucks looks great!
Thanks,
Bulletnjm likes this.
svc is offline   Reply With Quote
Old 07-22-2017, 11:24 PM   #198 (permalink)
ordered a set today
vr4henry is offline   Reply With Quote
Old 07-24-2017, 09:58 PM   #199 (permalink)
Ballistic's Avatar
Only took me a few months to get mine on..
Driver: 1.25"
Pass: 1.00"
Raised it about 2"
Tool supplied broke first try with hand pressure..
Very happy with it right now, seems to ride better. Taking it to the sand dunes in a few days for a long weekend..
Old 07-26-2017, 08:28 PM   #200 (permalink)
F150Feste's Avatar
@svc I'm interested to know this too, as I'm about to install mine here in Dallas next week (Mike G at Off the Grid offroad will be doing it for me) and curious if you can adjust if you have the truck up in the air (full droop) to allow for that top portion to spin along with the bottom part of the spring or if spring compressors are going to be needed each time? Any thoughts?
~Ernest Hemingway
Which coil for the 5.4L monk99 Ford Raptor Engine Discussion and Performance Mods-5.4 Liter Triton V8 [GEN 1] 11 12-25-2016 10:47 PM
Magnaflow Exhaust cat back system or welded in system? Renegade70 Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 14 09-28-2015 10:08 PM
3.0 coil overs. dfass16 ICON Vehicle Dynamics 3 05-27-2014 12:13 PM
Accel coil packs smarsha11 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 2 03-19-2014 02:04 PM
Rear coil suspension whtrapta Ford Raptor Exterior Modifications Forum [GEN 1] 7 09-01-2011 07:00 PM
