Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
RPG collars and negative effects during off roading
This is a discussion on RPG collars and negative effects during off roading within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Apologies of this has been covered already but I wanted to get everyone's collective wisdom on this. I've got the ...
Old 07-11-2018, 07:41 PM   #1 (permalink)
apeezie289's Avatar
Default RPG collars and negative effects during off roading
I've got the 1 1/2" rpg collars installed on my 2017 and I'm running 37s with methods.
Just last week we went wheeling in Moab, nothing too crazy but I was in and out of 4H for .ost of the day. Towards the end of the day I started hearing a loud popping noise when in 4H while maneuvering over obstacles. Then a few days later I engaged 4H again and could hear the same popping noises while turning.
I'm thinking the collars may have my CVs at too extreme of an angle? Anyone experiencing similar issues ?
Sent from my SM-G955U using Tapatalk
apeezie289 is offline   Reply With Quote
Old 07-11-2018, 09:41 PM   #2 (permalink)
you're going to hear some of that while in 4H/L, nothing to worry about. plenty of guys run 1.5-3" perch and spring upgrades without issue. Check your boots because they are more likely to tear with a perch kit/spring upgrade.
Megabass is offline   Reply With Quote
Old 07-11-2018, 10:54 PM   #3 (permalink)
So what's the noise? Unrelated to the collars?
BajaFred is offline   Reply With Quote
Old 07-12-2018, 12:33 AM   #4 (permalink)
No lift collars here and I don’t get any of that noise and I was out in mud and sand mode most of the time.
Booth9999 is offline   Reply With Quote
Old 07-12-2018, 10:30 AM   #5 (permalink)
Robtor310's Avatar
Dont Feed the Trolls
Same setup minus the 37s. I have about 20K on my collars and some healthy stints off road. I havent had any popping. The collars shouldn't be detrimental to the CV angle at all.
Curious though, can you elaborate more on the noise? So its when your turning, but what part of the suspension travel was it in, full droop, max compression, etc.
17 SCABALANCHE 802A 5-31-17 Build
Method | Baja Designs S8/S2/Squads | RPG Stage 3 w +2 Deaver, RPG 1.5" Collars | Icom 880H | Lowrance | Ford Performance Diff Cover | V1 Radar | LineX | BakFlip F1
Robtor310 is offline   Reply With Quote
Old 07-12-2018, 11:42 AM   #6 (permalink)
apeezie289's Avatar
It's like a loud knock or thud when either in 4A or 4h/L. I've got 22k miles , 21k with collar installed, 17k with 37s. Essentially you hear the noise when the IWE engages.
---------- Post added at 11:42 AM ---------- Previous post was at 11:41 AM ----------
Mostly when turning and accelerating hard or going over rocks and/or obstacles. Unsure sure about the suspension compression
Old 07-12-2018, 12:00 PM   #7 (permalink)
cayenne's Avatar
This is normal when going over rocks or hardpack with good traction. Especially when turning... When you are in mud or sand it's easier for the drivetrain to slip without binding up
GONE - 2012 Silver SCrew
GONE - 2014 Roush Ruby Red SE SCrew
2017 Lightning Blue SCrew
cayenne is offline   Reply With Quote
Old 07-12-2018, 06:09 PM   #8 (permalink)
apeezie289's Avatar
I hear what you're saying and it makes sense but the thing is I haven't heard this noise until now. Anyway as always thanks again guys appreciate the feedback !
Old 07-14-2018, 12:34 AM   #9 (permalink)
My truck made the same noise while performing a tight u turn on the street while raining. I was in weather mode (4a) and my truck is 100% stock. The manual covers this as well
Negative AmericanMuscle.com m2140 Sales Feedback 8 11-08-2017 10:19 AM
Wheel Offset and Weight and effects on handling Chayse Ford Raptor Wheels & Tires Forum [GEN 1] 13 12-06-2012 08:10 PM
Cold weather effects on the suspension. The Tank Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 5 12-18-2010 01:14 PM
Car and Driver Tests the Effects of Upsized Wheels BigJ Ford Raptor Wheels & Tires Forum [GEN 1] 6 04-30-2010 12:27 PM
