Rear suspension squeaking noise?
B
byz250f
maybe its where leaf connect to shackles ? maybe grease or wd40 that area and see if it stops temporarily. or start isolating exactly which junction is causing it..
you jumped yours or went to the oem bumpstops crunch so it really could be almost anything back there
Im going to let Ford figure it out...its under warranty so they can fix this issue. This squeaking issue has nothing to do with a jump as I have seen several gen 2 trucks that have never been offroad and they squeak.
2017svt
Do the Fox shocks have the steel bushings in the shock ends?
If so I would guess that's your squeak ?
They need to be pulled out and lubed.
My Maverick had that squeak as well and that's what it was.
Just a thought
Yukon Joe
Russellville, AR
I haven't noticed any squeaks on mine, and I have just over 6600 miles. I watched your video and holy crap yours is squeaky! It seems crazy that they haven't been able to fix it.
What video?
Sent from my SCH-I545 using Tapatalk
solarwinds
DFW
o didn't know that . thanks for that info.
ReefBlue
Delco . . .
I have it, but it isn't that loud. I'll probably just try penetrating oil on it.
New million dollar idea--spring bushings/pads with zirk fittings on them.
B
byz250f
Take it to the dealer...the more warranty issues ford has on a particular problem they will address it and fix it...thats why I dont fix things on my $70k truck..Ford can.
solarwinds
DFW
wait 4 it ^^
