Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
Rear Axle Shifted
This is a discussion on Rear Axle Shifted within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Thanks for all the advice gents. I spent about an hour under the truck yesterday and tried loosening the ubolts. ...
Like Tree8Likes
Old 05-17-2017, 07:06 PM   #11 (permalink)
Thanks for all the advice gents. I spent about an hour under the truck yesterday and tried loosening the ubolts. The bottom brackets shifted a bit, but overall the axle is where I started. It seem like, and I could be wrong here, that there are two bolts that connect the spring bracket on the axle to the leaf itself, sandwiching the bump perch in between. No movement is happening there. I totally unloaded the rear end, and...nothing. Shook the truck just to see, and...nothing. For the life of me I can't see anything that looks off other than the axle itself. Guess I'm making my service appointment.
MagnetMan14 is offline   Reply With Quote
Old 06-17-2017, 11:45 AM   #12 (permalink)
Junior Member
I have the exact same problem. 1 week old, they are sending to to the body shop to check the frame.... this is among the many problems I already have with this 70k truck!!!
MoralesJerad is offline   Reply With Quote
Old 06-17-2017, 09:48 PM   #13 (permalink)
Let me know if they figure anything out. They had my truck for over a week and were unable to diagnose the issue, though they were in 100% in agreement that there was an issue.
Old 06-18-2017, 12:19 AM   #14 (permalink)
Can you post a picture showing the drivers side vs passenger side?
byz250f is offline   Reply With Quote
Old 06-18-2017, 08:15 PM   #15 (permalink)
I'd like to see as well.
2017 Shadow Black SCREW 802A and other stuff.
sp2pilot is offline   Reply With Quote
Old 07-09-2017, 05:19 PM   #16 (permalink)
Magnetic1's Avatar
I have the same problem with mine, I just took measurements from inside the wheel well back wall. I am including photos of the measurements. I lined up the top and bottom tire wall in the photo to get the best measurement possible. The passenger side is about 18" from the inside fender and the driver side is 17 3/16". I am not sure if this is contributing to my bouncy suspension ride that I have or if this is just another issue.
Magnetic1 is offline   Reply With Quote
Old 07-11-2017, 02:34 PM   #17 (permalink)
Junior Member
Raptor is one month old with 2,000 miles. Same issue. Axle is shifted right (towards passenger side) about 1/2-3/4". Noticeable when looking down the sides of the truck. My truck hasn't even been off-road yet. Hasn't even seen a gravel road for that matter. Sucks Ford hasn't or can't do anything about it.
Mallard is offline   Reply With Quote
Old 07-11-2017, 11:42 PM   #18 (permalink)
Mine is shifted as well. Obvious whe looking out side mirrors. I'm struggling to not let it bother me.
Mkarban is online now   Reply With Quote
Old 07-12-2017, 09:05 AM   #19 (permalink)
SilverBolt's Avatar
Hired Gun
Did it shift or are you just noticing it? Wondering if the axle is really moving after some use or if they left the factory that way?
2012 Toyota FJ Cruiser
2018 Raptor Screw 802A White
SilverBolt is offline   Reply With Quote
Old 07-12-2017, 12:26 PM   #20 (permalink)
whoisbigman's Avatar
Apparently this is common. Most don't notice. I've seen pictures of crushed bump stops from the misalignment. Also seen thread where dealership was unable to resolve.
2012 Tux Black, Loaded. Previous owner added Spray-in liner, bed cover, LED everything, AFE intake, Magnaflow Exhaust, mid-perch... other stuff I haven't found yet. Thank You whoever you are... I have added 37" Nitto tires, painted speaker grilles, Roush vacuum gauge for hubs.
whoisbigman is offline   Reply With Quote
GEN 1 Rear end/axle lka Ford Raptor Problems and Questions Forum 5 05-23-2017 11:22 AM
GEN 1 Rear axle noise!? Auto-Hentzschel Ford Raptor Problems and Questions Forum 2 07-30-2016 12:14 AM
Rear Axle Rust VADER332 Ford Raptor Exterior Modifications Forum [GEN 1] 7 06-27-2015 11:56 PM
Rear end shifted? Jimbo Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 13 06-12-2015 12:36 PM
Rear axle and front axle assembly JJ f150harley Want to Buy 5 06-27-2014 04:42 AM
