Perch Mod Still Possible on 2017?
RPG
Orange County
That is easy. Its a two piece design. You would use a spring compressor on the springs then since no load you push up the spring seat take the two piece collar and bolt it together around the shock in the spot the stock seat was. Once locked in place you then remove the spring compressors
We installed a set today.
We removed the shocks so that we could ensure fitment and take a lot of pictures for install instructions.
