New gen2 long travel bed cage in the works
khcdave
South Brunswick NJ
Figured I would post up some pics of the new bed cage for the gen2 I am working on. Cutting material this week to build the prototype and test fit.
This is another modular design allowing you to run 2 tires standing up or 1 laying down to fit under a cover. Bolts to factory bed bolts so no drilling required.
Long travel shock mounts are incorporated into the design if you want to run 16 travel shocks through the bed.
Stay tuned for the install
khcdave
khcdave
South Brunswick NJ
Some real life pics. Protoype is almost finished and going in the truck for test fitting
byz250f
anyway to run 16 inch of travel without cutting through the bed?
bradyh20
Want pls. Can you make one that also holds a yeti 55?
