GEN 2 Installed SVC's Coil Adjuster System
Raptizzle
Raptizzle
FYT
Southern CA
So no desire to go with Fox 3.0's? Do ya think the cost vs the return on the fox shocks is not worth it?
I think a tunable aftermarket shock can be really beneficial after logging some more offroad miles. Adding some compression all around but most importantly upfront, could be huge. Obviously this is advice for guys going hard in desert terrain not really intended for stock raptors. The CAS is great for 37's, getting an exact ride height to suit specific needs, and 95% of the offroad terrain most raptors see.
I've got some plans in the very near future that I will be extensively testing and providing a write up. They don't involve Fox though. Stay tuned!
Forgiven
KIngs?!
I was thinking about getting a pair of kings for the front, better customer Service. But $3,500 is awfully steep.
galan.kelley
Finally got mine installed today. What spacing did you set your CAS at (inches)? I have mine set at 1 9/16” like the instructions called for, but it seems to be a bit much. Just curious, you don’t seem to have as much threads showing between the bottom of the threads and the bottom of the blue jam nut as I do.
