GEN 2 ICON .5-2.25" Attitude Adjustment Collar
AZ LucaBrasi
Chandler, AZ
Mine is set at 2.25", I put a tape on it and it's about 5/8" taller in the rear still.
I'm running Method NV's with 0 offset and 4.75" back spacing with the factory 315/70/17 BFG KO2's.
Here are a few pics!
it looks like you have yours set at 1.5 from the picture. At 2.25 you should be nose high. I have mine set at 1.75 ( 2.25 up on the collar without the .5 spacer) and its slightly nose high. If you have the 1.5 up as your picture shows and no spacer you you are at a net 1...if you added the spacer you are at 1.5.
R
Rick@FreedomMotorsports
He is correct.
You have it set for 1” or 1.5” but not 2.25”
You can see what we mean by this:
FullAuto
Finally installing mine next week after having them sitting in my garage for months. I'm going to stay with the 1.5" setting.
I will report back after I have some miles on the set up.
Hobert
I went with 1.75" a few weeks ago and think it is perfect.
Jeff manson
Cleveland OH
Hobert, your truck looks perfect with the 1.75 collar in the front. Slight rake in the front. Which is exactly what I’m looking for. Still no issues/concerns with your setup?
FullAuto
Man I think I posted these in the wrong thread the other day.
Ride is awesome compared to stock at 1.5". I tried them at 2.25" and it was noticeably stiffer and nose high. I didn't like the feel at all compared to stock or 1.5".
1.5" here:
Megabass
1.5" here:
Did you use the spacer on both settings?
