Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
How Did Ford Increase Wheel Travel
This is a discussion on How Did Ford Increase Wheel Travel within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Just Curious if anybody knows exactly how Ford increased front and rear wheel travel by 2", particularly in the front.? ...
Like Tree4Likes
Old 08-01-2017, 09:34 AM   #1 (permalink)
roostinyfz's Avatar
Default How Did Ford Increase Wheel Travel
Just Curious if anybody knows exactly how Ford increased front and rear wheel travel by 2", particularly in the front.? Also where is the travel found in the suspension cycle? Can't find any information on it. Thx!
roostinyfz is offline   Reply With Quote
Old 08-01-2017, 09:43 AM   #2 (permalink)
This is a complete WAG, but I'd guess that it's in the stroke of the shocks.
Life is hard; it's harder if you're stupid - Anonymous
Follow your dreams... unless you're a pedophile - Bill Burr
BurnOut is offline   Reply With Quote
Old 08-01-2017, 10:26 AM   #3 (permalink)
WarSurfer's Avatar
In the Gen1 there was physical binding that would occur, my guess is they made some simple changes to eliminate those touch points.
2010 SCAB
WarSurfer is offline   Reply With Quote
Old 08-01-2017, 10:35 AM   #4 (permalink)
Aaron's Avatar
Meme Corps Commandant
I think you're right. I'm betting they just tweaked the whole front just a little. Going from 12 (Gen1) to 13 (Gen2) wouldn't take much.
Suspension travel is AFAIK measured at the hub and is done by cycling from full droop to full bump. So for example on the Gen1 there's 12.1" of travel up front, but it uses a shock with an 8" stroke, so shock stroke doesn't tell the whole story there.
There's also different travel numbers that get cited in the off-road community. Basically total travel vs usable travel. Total travel would be the farthest extent the suspension can cycle, so metal to metal contact at both extents. Usable travel is the number you'll actually be able to put to use without binding or metal to metal contact.
COMMANDANT OF THE MEME CORPS
MCLTW!
It is not who we are that matters....what matters is our memes...
Aaron is offline   Reply With Quote
Old 08-01-2017, 03:58 PM   #5 (permalink)
So, the hub is mounted to the control arms, and the control arms move in an arc... so if the shock were attached to, say, the lower control arm between the pivot point (frame) and the hub (outer-most point of the control arm), then it certainly makes sense to have a hub/control arm tip total travel of 12+ inches with a shock stroke of 8 inches. Similarly, a relatively minor increase in shock stroke length would have an amplified effect on hub/control arm tip travel.
That said, if there are other gubbins that get in the way and/or bind up, then all bets are off, regardless of shock stroke.
Aaron likes this.
Old 08-01-2017, 04:40 PM   #6 (permalink)
Aaron's Avatar
Nailed it.
MCLTW!
Old 08-01-2017, 05:15 PM   #7 (permalink)
WhatExit?'s Avatar
LED headlights made it happen :)
PAW RAPTOR and Jred2255 like this.
WhatExit? is offline   Reply With Quote
Old 08-01-2017, 06:12 PM   #8 (permalink)
SilverBolt's Avatar
Hired Gun
New frame so it would not be tough to make a minor change in geometry that would net some additional travel. No idea if it is on compression or droop.
hkguns likes this.
2012 Toyota FJ Cruiser
2018 Raptor Screw 802A White
SilverBolt is online now   Reply With Quote
Old 08-07-2017, 07:21 AM   #9 (permalink)
Big-Foot's Avatar
Might have something to do with longer front control arms which also contribute to the wider track - then ilfting the entire truck ~3"... I could be wrong though...
Regards - Randy
2017 RubyRed Raptor
2015 Jeep JKUR / 2002 Jeep TJ
1933 Ford Tudor StreetRod
Racecar & HotRod Fabrication & Support
Big-Foot is offline   Reply With Quote
Old 08-13-2017, 12:50 PM   #10 (permalink)
WarSurfer's Avatar
The Gen 2 is 1/4" narrower than the Gen 1.
As I posted earlier, the increased travel HAD to have come from a redesign eliminating mechanical bind - otherwise the bind would still exist - and bind was the limiting factor on Gen 1s. Just adding a uni upper gave an additional 1.5" of droop travel while still using the factory 2.5s.
I'd be curious to see the difference between LCA coilover mounting points on the factory cast arms to see what changed there as well.
The Complete GEN 2 Raptor Information Thread
https://r.tapatalk.com/shareLink?sha...3&share_type=t
2010 SCAB
Ford raptor towing capacity increase. Justinb Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 18 09-09-2016 01:44 PM
Increase volume on steering wheel changes station justuspost Ford SVT Raptor General Discussions [GEN 1] 22 02-01-2015 04:42 PM
Ford ESP - Price increase RDFTS Ford SVT Raptor General Discussions [GEN 1] 1 09-30-2014 12:32 PM
Increase travel hackleman Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 3 01-31-2014 12:28 PM
Front Travel Increase BRONCOBOY1 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 16 06-14-2012 12:11 AM
