Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
Hellwig Swaybar installed
This is a discussion on Hellwig Swaybar installed within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
I drive 90+% urban and highway and don't anticipate taking my 18 SCrew to Moab or any super technical rock ...
Like Tree1Likes
Old 06-11-2018, 10:21 PM   #1 (permalink)
Default Hellwig Swaybar installed
I drive 90+% urban and highway and don't anticipate taking my 18 SCrew to Moab or any super technical rock crawling. Noticed that the Raptor had quite a bit more body lean than my '14 Z60 Sierra with 20" wheels. I read some favorable comments about the Hellwig rear sway and decided to try it.
Installed on the ground in my garage, took about a hour. Hardest part was snaking in the threaded backing plates into the frame rails. You have to work the plates into place by bending the guide wires to fish it to the frame rail slots so that the U shaped attachment for the sway links can be secured.
Simple hand tools are all that is needed. I mounted mine in the full loose end holes, and there are 3 holes in each end of the sway so its very adjustable.
First impressions - even in the loosest setting body lean is significantly reduced with no unwanted oversteer. No increased roughness noted either.
Very impressed, highly recommend this mod for non-crawlers
Heeblet likes this.
2018 Leadfoot SCREW/802A/Techno/moonroof/tailgate step/bed ext/cast wheels/Forscanned/Hellwig sway/RC lights/Dynamat factory sub
eclou is offline   Reply With Quote
Old 06-12-2018, 12:42 AM   #2 (permalink)
Junior Member
Sweet--I just got mine this last weekend and I will be installing it this week at some point!!! should be a great addition. Next on the list is the JB4
icecoldak is offline   Reply With Quote
Old 06-12-2018, 06:59 PM   #3 (permalink)
Can you take a sweeping right turn under speed (like an exit offramp) and tell me if you hear a grinding noise coming from the right side, maybe right rear
BajaFred is offline   Reply With Quote
Old 06-13-2018, 12:26 AM   #4 (permalink)
I have not heard any noise and have taken 45 mph ramps at 70-80 mph with confidence. One thing to look for is the guide wire used to fish the backing plates into place have to be trimmed after install - its possible that is resonating or rubbing against the frame
Old 06-13-2018, 10:12 AM   #5 (permalink)
Sozzy12's Avatar
Have the hellwig on my 250. Great product. Make sure you tighten it up periodically. Mine was loose enough it slide when going over a hill or bump and then stayed slid out of position, lifting one side of the bed.
2012 Raptor SCREW, tuxedo Black
2013 F-250 SCREW, 6.7 PSD
1966 Mustang GT w/ 306, T-5
1977 International Scout Traveler
Sozzy12 is offline   Reply With Quote
Old 06-13-2018, 10:32 AM   #6 (permalink)
what parts were loose? The axle mounts or sway links?
Old 06-13-2018, 01:33 PM   #7 (permalink)
TXRaptor's Avatar
Do you have any pictures of your setup?
2010 Raptor 6.2L SuperCab - Tuxedo Black, AFE Intake, True Duals w/ MagnaFlow, X-Pipe and Hidden Tailpipes, 5-Star Tunes
Perch Adjustment, 17x8.5 Black Methods, 35x12.50 General Grabber Red Letter, PTM Flares, Bumpers and Door Handles, ADD Race Series Bumper, Vision X LEDs, BakFlip, BedRug
2018 Raptor SuperCrew - Magnetic, 802A, 100% Stock (For now)
TXRaptor is offline   Reply With Quote
Old 06-13-2018, 03:15 PM   #8 (permalink)
Sozzy12's Avatar
The axle mounts. Got the impact on them and no problem since
Old 06-13-2018, 03:40 PM   #9 (permalink)
Good to know. I just re-torqued all of mine and tightened the sway to the middle hole. Middle gives quicker turn-in without oversteer and body doesn't lean at all through sharp turns. Highly recommend!
Old 06-13-2018, 09:06 PM   #10 (permalink)
Sozzy12's Avatar
It was funny, actually... I noticed after a wheeling incident, the bed appeared un-level. I stopped by the local Les Schwab (tires, brakes, etc place) and they thought my frame was bent. The tech didn't notice the aftermarket sway bar was sitting cockeyed. I got home and found out what my problem was. 10 minutes later all was good.
Hellwig Rear Sway Bar PN 7724 MTUH3 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 133 09-28-2017 12:33 PM
Hellwig Raptor Sway Bar P/N 7724 Humvee21 Garage Sale 5 09-26-2017 09:57 AM
Hellwig Swaybar Humvee21 Garage Sale 10 06-08-2016 10:54 AM
Swaybar quick disconnects? WhiteLightning Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 0 05-04-2015 07:19 PM
Hellwig EZ-990 Model 989 anyone? ZBoater Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 4 01-26-2015 04:01 PM
